tx diagnosis....and help??
I'm inthe Dallas area, and might need someone to help me fix this........
My car drives just fine, but when I get on the gas, in any gear, it bogs down. Bad. It doesn't backfire or feel like plugs/wires, and they got replaced a year ago (with the coil packs and module). My next guess is the fuel pump is going out. If this is the case, can anyone up here do it for a small fee, or 12 pack or something?
Please let me know what you think the problem might eb or if you need further detail. It really sucks pulling up next to a mustang and only being able to barely beat them cause of my sick car!
Jeremy
Jeremy
If you do not have the tools I would go to the dealer and have a diagnostic done so you know what's wrong. Here it is 75 bucks. That money would be worth your time and from buying parts you don't need. Otherwise, I would first check vaccum and fuel pressure and see if they are within range. Then check resistance of all wires, and the spark from the coil wire to the opti (be careful here).
Jeff D.
Jeff D.
