Parting out LT4 engine/tranny
Old Feb 8, 2004 | 05:24 PM
  #16
'95 LS1 Z28's Avatar
I still "have" everything. But the converter is temporarily spoken for. He is waiting for me to take the car apart. If he decides not to take it when its out then I will let you know. He accually wants to trade entire engines/trannys plus money so we shall see what happens. I am just waiting for him to get back to me now that I have thought about his offer.
Old Feb 10, 2004 | 04:27 PM
  #17
ttt
Old Feb 10, 2004 | 09:51 PM
  #18
red_warrior_z28's Avatar
interested in pro mags and torque converter. for sure if you dont sell the converter ill take.
email me info on rockers and stall.
Old Feb 11, 2004 | 05:58 AM
  #19
GT40MkI's Avatar
Re: Parting out LT4 engine/tranny
Originally posted by '95 LS1 Z28
OK here it goes:
LT4 heads with Comp dual springs, retainers, & locks $1500
LT4 intake w/fuel rail & stock injectors$250
BBK 58mm TB $250
All engine sensors $200
GM Opti-Spark(not aftermarket) $200
K&N FIPK cold air system $125
PCM(programmed to run a 360cid w/LT4 top, CC306 cam, and PT3600 stall converter) $150
Full engine/tranny wiring harness $250
360 cid (bored 60 over) 4 bolt main iron block with pistons, rings, rods, crank, and oil pan, no cam $900
Comp Cams 306 cam 230/244 .510/.540 112lsa $200
Comp Cams Pro-Magnum 1.6 Roller Rockers $200
A/C compressor, lines, dryer, condensor (90k miles) $150
Alternator (from O'Reillys, 600 miles) $50
Power steering pump (90k miles) $50
Stock 4L60E Tranny w/stock converter (90k miles) $300 Sale Pending to M-MAN
Yank custom built PT3600 Converter (200 miles) $600 Sale Pending to 'apr97ramair'
B&M Supercooler for tranny (200 miles) $50 Sale Pending to 'apr97ramair'
EVERYTHING has less than 500 miles on it unless otherwise noted.
I would like to sell most of the big stuff first otherwise I may as well not sell it.
I will sell it ALL (fully assembled) for $4500.
ill give you $50 for the compressor ..how long has it been sitting
is it open?
fyi you can get a new ps pump from autozone for $50 with lifetime warrenty
if you sell me the AC compressor i may take the alternator as well
email me mrfox1979yahoo.com
Old Feb 11, 2004 | 06:08 AM
  #20
OK, so the PS pump can go for $25 then. Everything is still on a running car so nothing has been "sitting". I will let you know when its all off. 5 people are in line for the Converter.
Old Feb 21, 2004 | 02:31 AM
  #21
sbs's Avatar
sbs
If you end up parting it out send me an email. Interested in the intake/rail/injectors.
Injectors are <500 mi? or 90k?
Old Feb 21, 2004 | 08:23 AM
  #22
New PM's have been sent out regaurding these parts to those who sent me PM's originally.
Old Feb 21, 2004 | 02:29 PM
  #23
will69camaro's Avatar
Opti spark is vented right? (new to LT1's) does it have 500 miles also?
Thanks,
William
Old Feb 21, 2004 | 03:27 PM
  #24
Yes it is the new style and more like 250 miles. Let me know if you want it.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
