Paging Ryan
Old Aug 16, 2002 | 01:05 PM
texz's Avatar
Post Paging Ryan
Do you work this Saturday? I just had a big problem with my car today. No overdrive. It has been making a grinding noise in the rear for about 2 weeks now. I thought it was the rear springs. They were off the mounts so I put them back on yesterday but the grinding was still there. Now, on 281 today, no overdrive and Drive takes a few seconds to engage. Did I blow out my rear? On my car. I need someone to check it out soon, since it's my only car.
Old Aug 16, 2002 | 01:26 PM
96speed's Avatar
Wink
I only work mon-fri .
Jokes aside...Sounds like transmission trouble...
Ryan
Old Aug 16, 2002 | 02:50 PM
texz's Avatar
Angry
I hope not. I just put a new trans in 2 years ago. Guess I better dig out the paper work on the warranty, just in case. All the other gears work, it just takes a little longer for them to kick in and the OD is dead.
Old Aug 16, 2002 | 03:43 PM
96speed's Avatar
Red face
Good luck man.
Ryan
Old Aug 16, 2002 | 11:23 PM
texz's Avatar
Post
ttt
Old Aug 16, 2002 | 11:54 PM
AHARTZ28's Avatar
Post
me? if so i do work tommorow
1994 Z28 A4
383 scat 9000 series crank, eagle rods, wiseco 12:1 pistons CC306,TCI Streetfighter,HOOKER LT's,Meziere H20 pump,LT1 Edit,95+ opti
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
The Beastdual exhuast
Old Aug 17, 2002 | 12:05 AM
texz's Avatar
Post
Oops. My bad. Yes, that was for you. I will bringing my car to Gunn (Pontiac?) this morning. I called but they said you just left so I just missed you at work. Does this sound like gears or the trans? OD works at slow speed, maybe up to about 20 mph, and D works but I have to let off the gas to get it to shift. This is sort of what happened when my trans went out but I still had OD then. It still has the grinding noise coming from the rear at low speed when the steering wheel is turned. Sounds like the driveshaft is hitting something. This new thing started Friday.
Old Aug 17, 2002 | 11:39 PM
texz's Avatar
Post
Ryan, did anyone get a chance to look at my car today? Go ahead with the gear swap, when you can. Let me know if the rear diff fluid looks like the right kind. I had Jiffy Lube change the fluid the day the problem with the rear started. Before the problem started. If it's the wrong kind then they will be paying for that part. I would buy the heads you are selling but I have to pay off an important piece of jewelry first.
Old Aug 18, 2002 | 09:12 AM
AHARTZ28's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by texz:
Ryan, did anyone get a chance to look at my car today? Go ahead with the gear swap, when you can. Let me know if the rear diff fluid looks like the right kind. I had Jiffy Lube change the fluid the day the problem with the rear started. Before the problem started. If it's the wrong kind then they will be paying for that part. I would buy the heads you are selling but I have to pay off an important piece of jewelry first. </font>
i didnt get a look at it but it is my first one monday morning, what i will do is swap the rear after we look at the trans that way the speedo isnt off, then i will do the rear..i will email you
1994 Z28 A4
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
Old Aug 18, 2002 | 01:57 PM
texz's Avatar
Thumbs up
Sounds good. Thanks a lot! I already miss my baby.
Fatdog2
Sep 16, 2015 11:04 PM
cmsmith
Aug 27, 2015 06:37 PM
97blackformula
Aug 27, 2015 06:02 PM
WPHIG2
Aug 27, 2015 06:37 AM
cmsmith
Aug 20, 2015 07:57 PM
