Paging AHARTZ28
Old Aug 20, 2002 | 11:06 AM
T-Rod's Avatar
Post Paging AHARTZ28
Ryan,
What kind of deal can you get me on an oil pump install. Mine is starting to crap out and i want to get a new one before this one completely fails. I may need to replace the sending unit also. Thanks.
Old Aug 20, 2002 | 06:37 PM
AHARTZ28's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Billy Bad WS7:
Ryan,
</font>
is it an LS1? if so i will o it and the sender for $175
1994 Z28 A4
383 scat 9000 series crank, eagle rods, wiseco 12:1 pistons CC306,TCI Streetfighter,HOOKER LT's,Meziere H20 pump,LT1 Edit,95+ opti
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
The Beastdual exhuast
Old Aug 20, 2002 | 06:39 PM
T-Rod's Avatar
Post
Ryan, that sounds great and it is a '98 Trans Am. Let me try to get an aftermarket one down here before mine totally craters. When can you do it??
Thanks.
[This message has been edited by Billy Bad WS7 (edited August 20, 2002).]
Old Aug 20, 2002 | 07:42 PM
AHARTZ28's Avatar
Post
should be able to do it next week
1994 Z28 A4
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
Old Aug 20, 2002 | 10:59 PM
T-Rod's Avatar
Post
Ryan, that pump gave up the ghost tonight when i was getting ready to go to the sonic meet. I started her up and the gauge read "0" oil pressure, so i turned it off, and started it again and same thing. I didn't leave it on long enough to hear any knocking or grinding, but i know that zero oil pressure is bad and that it always springs up on start-up so something definitely quit working. Email me at thop225@hotmail.com so we can schedule a time. Thanks again.
Old Aug 21, 2002 | 02:28 PM
T-Rod's Avatar
Post
Ryan,
I also ordered a timing chain for it, how much more to put that in at the same time?
Old Aug 21, 2002 | 06:47 PM
AHARTZ28's Avatar
Post
well while im in there we should put in a cam
1994 Z28 A4
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
Old Aug 21, 2002 | 06:52 PM
T-Rod's Avatar
Post
How much for the cam install, along with everything else??
Old Aug 26, 2002 | 08:04 AM
T-Rod's Avatar
Post
Hey ryan,
While your up under there, could you see what you could do about the y-pipe. If you look, you'll see where it is killing the floorboard. If you could adjust if while you had it on the lift that would be wonderful. Thanks.
Old Aug 26, 2002 | 12:22 PM
AHARTZ28's Avatar
Post
Hey ryan,
</font>
i will do that, i am also going to pull your filter off an make sure you didnt tear up a bearing too ok
1994 Z28 A4
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
Old Aug 26, 2002 | 06:41 PM
T-Rod's Avatar
Post
Sounds good, Thanks.
Old Aug 27, 2002 | 06:37 PM
AHARTZ28's Avatar
Post
i got the cover off i have to drop the pan what oil do you use mobil 1?
1994 Z28 A4
1/4:11.89
11.64 corrected
MPH:115.23
1/8th:7.6x
60':1.77
Old Aug 27, 2002 | 06:39 PM
T-Rod's Avatar
Post
I use royal purple 5w-30. do you want me to drop a few quarts by? Also when do you think it will be finished?
[This message has been edited by Billy Bad WS7 (edited August 28, 2002).]
Old Aug 30, 2002 | 07:31 AM
T-Rod's Avatar
Post
Ryan,
For some reason the low fuel light came on, when the tank was completly full. Do you know why this could be and could it be related to the oil pump and timing chain install? Thanks.
Old Aug 30, 2002 | 11:56 AM
ford's Avatar
Post
I dont think those things will be related at all.... Might just be one of those things!
Dunno what would cause it though.
BTW nice car!
