Need a 4 bolt main LT1/4 block
Old Nov 17, 2003 | 03:01 PM
onebad96T/A's Avatar
Need a good block, anyone have LT1 4 bolt main block for sale or trade? Dont need pistons or rods just a good condition bare block.
Old Nov 20, 2003 | 08:03 PM
Old Nov 21, 2003 | 09:31 AM
All_Z_Way's Avatar
If you don't find a 4 bolt.. I have a 2 bolt.
Old Nov 21, 2003 | 05:34 PM
texlurch's Avatar
I have what is suppossed to be a virgin 4-bolt block.. never checked the bores to verify, but it doesn't appear to have been run.
$250
Old Nov 23, 2003 | 09:20 AM
Bodenham's Avatar
texlurch-
Let me know if block is not sold to onebad96 - don't want to ambulance chase, but if he doesn't want the block, I'll take it, assuming:
it is stock bore
mains are not damaged
it is indeed a 4 bolt LT1 block
Cam bores not trashed
Not a rustball or broken/damaged
Lemme know.
Thanks,
John
Old Nov 23, 2003 | 10:25 AM
texlurch's Avatar
I'll put the snap gauge to it tomorrow, but I am pretty sure it is virgin. I bought it a couple years back for a project, but never built it. It is sitting in a Vega for a "dummy" motor right now...
Might have a 383 Scat crank for sale also.. have to verify another plan before I put it up.
Old Nov 23, 2003 | 02:49 PM
texlurch:
What do you want for the block and the crank?
Thats if there is nothing wrong with the block i dont mind if its a fresh 30 over bore.
Old Nov 23, 2003 | 05:42 PM
texlurch's Avatar
Looks like I will hold onto the crank for a while. The other one I was thinking of is a 2-piece seal.
I'll verify the bore on the block tomorrow; there is nothing wrong with it at all.
Old Nov 24, 2003 | 11:47 AM
texlurch's Avatar
Bore measures out to 4.001; doesn't look like it was ever finish honed. The cam bearings also don't show any wear. I don't remember (had it for a few years now), but it seems to me it was represented as virgin when I bought it.
Has some minor surface rust in a couple cylinders from sitting around "seasoning", but nothing to worry about. PM or email if you are interested, because I need to figure out a time frame. It is currently holding up my LT4 heads in a buddies Vega so we can build his exhaust.. so I need to get to work!
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
