Misc LT1 parts in DFW- M6 flywheels, TA wheel, O2's, brake pads, etc
cleaning out the shop today and found a few things i don't need anymore. everthing is located in mesquite at the moment, but might be able to meet you somewhere resonably close or ship the small stuff at your expense. feel free to ask any questions.
-2 bosch o2 sensors, used for maybe a week. i had a bad opti, but changed all sorts of stuff hoping it was something else. i ended up putting the stock ones back in it after it didn't fix the problem. *SOLD*
http://img339.imageshack.us/img339/1...sensorskr1.jpg
-5 spoke TA wheel (straight spoke kind). has a small flat spot on the lip, but holds air fine. no curb rash, but has some red paint overspray and a few chips here and there. comes with an extra center cap and about 2 sets of lug nuts and covers. $40
http://img339.imageshack.us/img339/3413/wheel1wa5.jpg
http://img339.imageshack.us/img339/9008/wheel2wq4.jpg
-2 M6 flywheels. both have no missing or chipped teeth. both will need to be resurfaced obviously. one is rusted pretty bad but could probably be cleaned up, no history on whether its been turned before or not. the other is fairly clean, it was the original out of my car at 120k miles and shouldn't have ever been turned. $60 for the better one, $20 for the rusted one.
http://img339.imageshack.us/img339/8...ywheel2qy6.jpg
http://img339.imageshack.us/img339/5...ywheel3lk3.jpg
-brake pads. one set of front Hawk blue's with a lot of use left. the previous owner used to do track days and this is what he used. the other is a set of performance friction carbon metallic fronts with lots left, and one set of rear pads that are somewhat used. $40 for all.
http://img339.imageshack.us/img339/4012/brakesht5.jpg
-ABS module. i bought this used and was told it was good and came off a '95 firebird, but i never had it installed in my car to find out. there are part numbers all over it, the 2 main ones are 18018361 and 42412603. you might want to check the ones on your car first. $40
http://img339.imageshack.us/img339/4158/abslt6.jpg
-misc taylor spark plug wires. 10 plug wires and 2 coil wires. used, but most if not all of them should be good. i was always burning up wires on my headers so i bought a few sets and kept the older good ones as spares. *SOLD*
http://img339.imageshack.us/img339/7412/wiresjn0.jpg
-Z28 emblems. these are factory gm adhesive backed emblems that go on the sides or the tail. $10 for the 2 of them
http://img339.imageshack.us/img339/3792/decalspt6.jpg
-coil, oil filler cap, (2) 180 thermostats, stock knock module, and an alternator pulley cover? $10 for it all.
http://img339.imageshack.us/img339/7349/miscwx8.jpg
-bosch platinum spark plugs. new, but no box. i believe these are the +2 plugs, but they don't have any part numbers on them. i don't know why i only have 4 of them, but thats all i could find. $10 for all 4.
http://img339.imageshack.us/img339/4347/plugskp5.jpg
-and as always, i still have a few hundred lbs of raw carbon fiber cloth if you have a need to make something.
http://img301.imageshack.us/img301/8176/spoolsod4.jpg
