I need some help please!!!
Old Mar 24, 2003 | 10:33 AM
97SSmokem's Avatar
I got in an accident this past week. (not in the Camaro, although it's out of service as well). Anyway, I got hit on the freeway partly my falt the result of this is a bent rear axle. I need some help in getting the old axle out and a new axle in. If someone could help me today I will buy them lunch and have plenty of (DRINKS) to help in this project. I really need to get this done today so please someone give me a call. 347-3857. Ryan if your not buisy that woudl be great and I could make myself available to help you move, I have access to many trailers so that might help as well. Please let me know.
Old Mar 24, 2003 | 01:30 PM
Pony Punisher II's Avatar
I see you have a Moser rearend. I'll assume it's a 12-bolt
It's really EASY to replace axles, since they bolt in. You don't even have to take the rear cover off.
First, remove the wheel. Next, take the brake caliper/bracket assembly off. Then remove the (4) 9/16" bolts behind the axle flange. Then pull the axle out. You may need to tap it out from the back with a hammer, or use a prybar. But it should come out with little resistance.
Good luck
Old Mar 24, 2003 | 02:58 PM
97SSmokem's Avatar
Thanks but it was in my truck that I had the accident. I got everything out all I have to do is get the old bearing out but I can not get it out. I bought a bearing puller but I don't really know how to use it. Drinks are still on me if anyone can come over.
Old Mar 24, 2003 | 04:20 PM
AHARTZ28's Avatar
i would be glad to help you but i am in the middle of a move right now, i may be able to help out tuesday or thursday night let me know ok
btw do you live near randolph?
Old Mar 24, 2003 | 05:11 PM
If I didn't live 300 miles away, Id help
You probably need a shop press to get the bearing off(provided the bearings are pressed onto the axles). If you dont know anybody that has one, just go to a reputable machine shop and Im sure they can do it.
If the bearing is in the axle tubes(housing), you need a slide hammer and the puller jaws that go in behind the bearing.
Old Mar 24, 2003 | 10:26 PM
97SSmokem's Avatar
Well after many head scratches and large amounts of alchol, everything is back together. Thanks anyway, it really wasn't as bad as I thought it would be. Ahartz, if you need help still let me know. I can get two trailers plus my truck.
Let me know.
