Hey Ryan, need help ASAP!
My car has gone through about half a gallon of coolant in the last 2 days. There are no puddles under the car so it must be going somewhere inside. Blown gasket? When can I bring it in to get this checked out. And since I still need the cam/springs installed...
I had the gears sitting in the garage when the rear and tranny went out a few months ago so it seemed like the perfect time to get the gears and stuff put in. Maybe this is another sign from above that it's time to get the cam, springs, etc out of the garage and into the car.
Let me know when you can help me out.
P.S. It's the green Z28 that you did the gear swap on. I finally got the Wife Mod installed so now I can start showing up at meets again.
I don't think I'm the Ryan you're looking for, but I will take a stab. If you are seeing white smoke in the exhaust gases you should plan on removing the cylinder heads and replacing the gaskets.
Ryan
Ryan
Eddie, I appreciate the offer but I got that issue resolved. Ryan, I don't do business via e-mail. When hundreds if not thousands of dollars are on the line, in person or on the phone is the ONLY way. I asked you on numerous occasions to call and you didn't. I assumed you were too busy and went somewhere else. Nothing personal but if I expected MY clients to handle our business transactions via e-mail only I'd be a broke man. No hard feelings, though.
Brake_L8
Jan 20, 2015 09:44 AM
mike24
Aug 7, 2002 10:06 PM
