help with coolant lines
Old Apr 21, 2003 | 08:57 PM
kaoticcamaross's Avatar
The coolant line that i have not sure if it's the only one or not but it runs into a metal tube at one end and at the other end it comes over a metal tube and is kept on by a clamp. I need to replace this line. Does anyone know what i'm talking about and if you do how much does it cost to get replaced?
Wes
Old Apr 21, 2003 | 09:16 PM
1965GP's Avatar
Where exactly is it? I don't have much f-body experience, but I don't think it would be that hard if it's just a coolant line.
Old Apr 21, 2003 | 09:43 PM
yes um right above the right tire well kind of to the side of it is 2 metal lines. The bottom one connects to this coolant line. Thats the one i need to replace.
95GRNZ's Avatar
Cool
Interesting description... But I still have no idea which hose you are talking about...
Might want to post in the appropriate Tech section, too.
Good luck!
TS
Old Apr 22, 2003 | 12:41 AM
96speed's Avatar
Sounds like you're talking about the heater core lines. They are opposite the passenger side manifold, right? If so, you have to replace the complete metal assembly. Maybe you could get the correct size rubber hose, cut it to fit, and clamp it?
Its really difficult to get an idea of what you're describing. Anyway for you to get a pic?
Ryan
blac94Z
Feb 15, 2021 09:43 PM
calaban
May 18, 2020 06:43 PM
HarleyZ28
Oct 5, 2015 06:23 AM
LingenfelterZ28
Apr 24, 2015 12:14 PM
MattFick
Feb 15, 2015 10:16 PM
