FS: Heads, Forged Shortblock, Th350setup, ls6 intake etc
GTP Stage 2 5.3 heads, combination motorsports springs, ferrea 2.02i 1.57e severe duty valves. Fresh Valve Job and additional porting by "Lump" in houston. These heads are 2300 + Core........asking $2000
Ls6 block w/ stock rods and crank, JE domed pistons, compression was 11:2 to 1 w/ above heads. clevite bearings, arp rod bolts, diamond pro piston rings, MTI R1 cam, 0 miles, machine work done by Jeff Naiser.....$3000
Transking Th350, B&M pro ratchet shifter and cable, tranny cooler, custom crossmember, J9 transking converter, lokar dipstick tube, everything needed for swap into f body.....$1300
Ls6 Intake w/ NO egr.....$325
Hal Shocks (both front and rear shocks, also front and rear coilover springs and spanner wrench)....$500
BMR Chromoly K member.....$300 + Stock K member
Stock Lifters & lifter covers....$60
M6 PCM tuned for above combination.....$150
Complete uncut 98 Wiring Harness.....$200
Ported TB for 98-99 cars.....$75
Starter....$75
Radiator...$75
Fans...$125
Alternator...$75
A/C condensor and compressor....$150
Power steering pump....$100
Comp Chromoly 7.4 pushrods....Sold
Comp Chromoly 7.35 pushrods....$70
Centerbolt valvecovers.....$40
Coil Packs and brackets.....$100
28lb Injectors and fuel rails......$120
Stock unported MAF w/ no screen....$50
Hypertech 160 thermostat w/ housing....$20
All parts are + shipping. Email bad1lez@yahoo.com or PM to make offer or for questions.
Starter....$75
Radiator...$75
Fans...$125
Alternator...$75
