FS: Comp XE 230/236 and more...
Old Aug 22, 2006 | 09:10 AM
quicksilver97ta's Avatar
Comp Cams XE 230/236 for sale, used approx 5k miles. This cam made nearly 400 hp w/ LE heads and a mail order tune on a 100 degree day. It also has the correct dowl pin length. ................... $150.
Cam Dynamics 1.6 NSA aluminum body full roller rockers for a 7/16 stud used 2k miles, 7/16 guideplates used 5k miles with no issues, complete set 3-piece hardened pushrods (7.2") stock length, new except for 1 used .................. SOLD. Thanks cz28!
LT4 ED timing set used 5k miles, no w.p. gear....................SOLD. Thanks cz28!
Aluminum LS1 driveshaft, NOW AVAILABLE.....................$125
Currently has a 1350 conversion U-joint
STD LT1 crank, great shape, run w/ synthetic oil 60k miles w/ no issues .................$50
stock rods and pistons available too.
Can deliver to Cedar Hill GTG, shipping extra.
Old Sep 11, 2006 | 02:04 PM
Re: FS: Comp XE 230/236 and more...
Ttt
Old Sep 11, 2006 | 05:15 PM
snakeatinZ's Avatar
How much for all of this?
Thanks,
Steve
Old Sep 11, 2006 | 09:29 PM
porksoda's Avatar
Will the roller rockers work on a LT1?
Old Sep 12, 2006 | 09:07 AM
Steve, if you pick it up $75 takes it, I think I even kept the bearings too since they were in great shape. Note: two of the pistons have very minor blems on the tops from a piece of valveguide floating around. They should be good to go after some clean up with sand paper or steel wool. I just used this as a reason to build a stroker.
Porksoda, the rockers will work on an LT1. Note: they are non-self aligning, you need to run these with guideplates, using guideplates requires hardened pushrods, and these are for 7/16 studs not stock 3/8 studs but you can change those too. This makes for a very solid valvetrain, much more reliable than SA rockers and 3/8 studs.
Old Sep 12, 2006 | 10:38 AM
porksoda's Avatar
Whats LSA is the cam cut on and what lift does it hve with the 1.6 RR's?
Please send pics of the valvetrain stuff and the cam to tupacs_alive2004@yahoo.com. Thanks!
Old Sep 12, 2006 | 12:53 PM
112* LSA and the lift is around .580 with 1.6's.
Old Sep 12, 2006 | 05:42 PM
snakeatinZ's Avatar
[QUOTE=quicksilver97ta]Steve, if you pick it up $75 takes it, I think I even kept the bearings too since they were in great shape. Note: two of the pistons have very minor blems on the tops from a piece of valveguide floating around. They should be good to go after some clean up with sand paper or steel wool. I just used this as a reason to build a stroker.
I will take the crank for your asking price. I found out a friend of mine has rods and pistons sitting in his garage... I cant beat free. Would you happen to have any t. body to intake bolts? Can you pm me your address? I want to come pick it up to save on shipping.
Steve
p.s. how would that cam do on stock heads? I am interested in it but it is out of my price range for this month. Ill take it for 125.00, but I need to split it up it to two payments? Think about it and LMK.
Old Sep 12, 2006 | 06:44 PM
RedWS6TA's Avatar
i will buy the rockers, guide plates and pushrods if they are still for sale. please consider them sold. and i am in abilene maybe we could meet somewhere instead of shipping.
RedWS6TA's Avatar
Old Sep 13, 2006 | 01:50 PM
PM's sent. Sales pending.
Old Sep 13, 2006 | 05:53 PM
snakeatinZ's Avatar
Pmed you back.
Steve
Old Sep 14, 2006 | 08:53 AM
Originally Posted by snakeatinZ
Pmed you back.
Steve
PM back at ya
Old Sep 15, 2006 | 09:04 PM
porksoda's Avatar
I was still waiting on pics of the stuff. Damn I missed out on a good deal!
Old Sep 18, 2006 | 08:20 AM
Rockers, guide plates and pushrods are sold.
Cam still for sale. Pics sent porksoda.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
mightymouse383
May 21, 2015 05:31 PM
alliance12364
Mar 6, 2015 04:39 PM
