FS: 400+ HP Formula in Houston
Old Aug 28, 2003 | 12:40 AM
96 formula's Avatar
I'm selling my baby I need to buy a truck so I can pull a new boat.
pics can be seen here: http://blacktxb3000.20megsfree.com/formula/
here is the run down:
DynoJet: 407 HP @ 6500rpm
362 ft-lbs @ 4800rpm
1996 Pontiac Formula
Six Speed, Black w/ tan leather interior, T-tops, power everything, 10 speaker stereo w/ cd, all options.116,000 miles on car, 16,000 miles on new motor. Professionally built 355 LT1 converted to a 4 bolt main with splayed billet caps, all ARP fasteners, Wiseco forged pistons, shot pinged and coated, Clevite 77 bearings, rotating assembly balanced, Meling high volume oil pump, GTP stage II heads, 2.05/1.6 valves, Comp cam triple valve springs, titanium retainers, Ferrea valves, GTP6 .568/.592, 235/242 dur @ .050, 112 LSA, AFR Hydra-Rev kit, back dated OBDI custom matched computer program to setup, STAR stage III ceramic clutch, MTI cold air w/K&N filter, Granatelli mass air flow sensor, ASM 58mm throttle body, GTP ported/polished/gasket matched LT1 intake manifold, Hooker long tube competition headers JetHot coated, custom y pipe, Borla cat back exhaust, MTI underdrive pulley, Comp Cams Pro Magnum 1.6 roller rockers, Comp Cams chromemoly pushrods, Comp Cams pro magnum roller lifters, GM Extreme Duty roller timing set, Aeromotive adjustable fuel pressure regulator, Hypertech 160 thermostat, Meziere electric water pump, NGK plugs, Taylor race wires, MSD ignition, new GM coil and opti-spark, Eibach springs, Bilstein struts, subframe connectors, adjustable panhard rod, Boyd Codington wheels 17 x 9.5, new Kumho tires, white face gauges, Autometer electric fuel pressure gauge and air/fuel wired to both O2 sensors w/toggle switch
$8500 obo
Interest, questions...pls email me
jamestbuck@yahoo.com
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
tommalcolm
Sep 11, 2015 03:39 PM
