Freshened aluminum LT1 heads
Old Dec 10, 2007 | 09:12 AM
mitchntx's Avatar
From a 96 LT1.
The heads have been freshly built by Wayne Calvert in Denton. They are complete with fresh seats and valves, angle cut valve job, new LT4 springs and locks.
Unfortunately, I can't use them. They had been cut previously and he cut another .015 off to get them flat. That would put the compression ratio to 11.2 to 1 which is over the limit of the rule set I run under.
The combustion chambers are measured at 52cc.
These will bolt right on and you get a nice bump in compression.
Looking for $450 plus a set of good cores.
Heads are located in Ft. Worth
Old Dec 10, 2007 | 02:35 PM
MeanGreen97Z's Avatar
Are they ported at all?
Old Dec 10, 2007 | 03:19 PM
mitchntx's Avatar
Not ported ... 100% stock and ready for a port job.
Old Dec 16, 2007 | 09:49 AM
mitchntx's Avatar
These some great heads.
*Emilia*
May 13, 2015 09:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
