the beaSSt is running again
after a long 1 1/2 weeks after spinning the rod bearing the impala is running again. i replaced the stock lower end with another stock lower end. i put in a good pump so i shouldnt have this problem again...
Originally posted by Bloodztone
Dang Ryan you don't waste time do you?
I hope the ride only gets stronger from now on.
