Bad hesitation...Help
Old May 10, 2003 | 07:37 PM
97SSmokem's Avatar
I 've got a bad hesitation when under power. Also, the service engine soon light is on. Code is for the Mass air flow sensor. I changed out the MAFS and it did no good. I have no idea what is wrong. The MAFS is good I know this for sure.
Any sugestions?
Old May 11, 2003 | 01:14 AM
Bloodztone's Avatar
EGR, same problem Firebird_fury was having.
Old May 11, 2003 | 02:19 AM
AW/whiteZ-28's Avatar
Make sure it's facing the right way I dunno if it has anything to do with it but I got in a rush and put it on backwards once
Old May 11, 2003 | 09:48 AM
97SSmokem's Avatar
OK brain fart, what is the EGR and where is it?
Old May 12, 2003 | 07:59 PM
97SSmokem's Avatar
OK found the EGR valve and there was a loose vacum line. So i pluged it back in but the service engine light is still on and there is hesitation. How many miles before the computer resets itself?
Old May 12, 2003 | 09:46 PM
AHARTZ28's Avatar
OBD2 wont go by miles, it wil clear the light after 3 passes on it on the ignition cycle. the code will clear after like 130 sysles of passing
if you have a MAF code loook for a fuse blown or wire broken
Old May 12, 2003 | 10:02 PM
97SSmokem's Avatar
Hey thanks, everybody. Ryan, can you do those headers and gears for my buddy this week sometime? Let me know.
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
