Anyone want to install a N2O kit for me?
Old Nov 6, 2004 | 07:37 PM
dmoor88's Avatar
Can anyone install a N2O kit for me? I'm not about to try and do it myself...whenever I choose a kit, that is. Im going to be getting a NX 50-125 wet shot with all the goodies and am going to want someone to install it for me.
Im in Waco, Texas but will be willing to drive practically anywhere in Texas for the right price...
Old Nov 6, 2004 | 07:46 PM
ford's Avatar
Re: Anyone want to install a N2O kit for me?
Hmm let me know who you have do this and how much...I suck at wiring electrical stuff up. I can set everything up, but i know id mess up with the ignition box, window switch, purge, fpss, WOT switch....
Old Nov 6, 2004 | 10:15 PM
dmoor88's Avatar
I've found one guy on dfwls1.com that'll do it correctly for $150. I'm still getting a feel for what people are charging...
Old Nov 6, 2004 | 11:21 PM
waldo1979's Avatar
do it yourself its easy its only 2 wires
Old Nov 6, 2004 | 11:24 PM
ford's Avatar
Not when you have 100 different safety things to wire up
Old Nov 6, 2004 | 11:28 PM
ford's Avatar
Btw, what all does that $150 include? I have all the mechanical stuff mounted, but i need someone to wire up the purge, wot switch, window switch, and wire in the solenoids and stuff.
Old Nov 7, 2004 | 01:51 AM
disco192's Avatar
come to austin... I can bust it out for 50 bucks and you provide the beer. I can wire up just about anything. Ill also walk you through everything. Its really not complicated if you know how everything works and where the signals come from.
Im setting up my new motor and if you wanna help do some wrenching, ill do it for free. My car is also in Temple which should be close you if you're in Waco.
Just make sure your fuel pump can handle it and you get all the saftey precautions (WOT switch, window switch, good noids....)
Old Nov 7, 2004 | 01:56 AM
dmoor88's Avatar
Id more than likely use the 'trap door' method and install a new Walbro 255 FP before I think about getting a N2O kit.
Old Nov 7, 2004 | 07:07 PM
ford's Avatar
Ill take ya up on that offer, as soon as my car is running again
What do ya drink?
Old Nov 7, 2004 | 07:42 PM
dmoor88's Avatar
yeah ill take you up on it as well. im only about an hour from austin so its all good.
any advise on a decent NX wet kit with 50-100 shot?
Old Nov 7, 2004 | 07:49 PM
ford's Avatar
I just bought mine used, however i would suggest just getting a new one as i got kinda screwed in alot of ways on some parts, like my purge
Hell if i get my old purge warrantied id be willing to make ya a deal on the one they replace it with
Old Nov 7, 2004 | 07:54 PM
dmoor88's Avatar
so how much should i be looking at dropping on a new nx setup like i described? how many different ones are there for the shots that i specified?
Old Nov 7, 2004 | 08:12 PM
ford's Avatar
Well the basic kit is about $589 i think. I used a mallory 685 ignition box $239.00(that has my window switch and timing retard built in), then the basic kit comes with the WOT switch.
And the basic wet kit includes jets for 50, 75, 100, and 150 shots.
Then colder plugs and you should be just about set. If you want a purge, bottle warmer and stuff then the upgrade to the Genx II kit is about $300 more.
it really just depends on how much you want to spend and how far you wanna go on the safety accessories.
But i think the window switch, timing retard and WOT switch should be more than enough for ya.
i also bought guages for everything, nitrous pressure, fuel pressure, and A/F ratio
Old Nov 7, 2004 | 08:44 PM
dmoor88's Avatar
yea tr6's are definitely going in along with the walbro 255. ill have to look into some ignition boxes...
thanks ford.
Old Nov 7, 2004 | 09:46 PM
waldo1979's Avatar
my kit is forsale $280
