Anyone wanna install my valve springs and rocker arms?
I dont have time to do it myself and need someone experienced enough to put my valve springs and rockers on while I am at work. Let me know when you can do it and how much you want.
, If you can tear everything apart, shim & install springs at recommended installed height, install new valve seals, set all the valves & put everything back together in less than 2 hours, YOU ARE THA SHIZZLE
Valve seals are fine.... no shims... lol I didnt get any. Im sure it will be a pull the stock springs, install the lt4 springs, and install the rockers. I've done this pretty quick before and I seem to bs much less now.
oldschool
Feb 9, 2016 09:21 PM
