Anybody seen the emissions checkers?
Has anybody else seen these? They are little checker deals that are set-up on the on-ramps to freeways. I have seen a few around rockwall. I was reading up on them and if you drive through it and ur car doesn't check ok. They will flag your plate number and when you try to get the car registered the next year they wont let you register it until you can prove it passed a full emissions test in the county you were caught in. This sucks since I have no emissions equipment on my car b/c I live in a non-emissions county.
I just figured I would give everybody a heads up so if you know your car isn't emissions legal I wouldn't drive through one of these things. |
The trick to these is to coast past them, don't accellerate past them. If there is no exhaust they can't read it.
Anyway, that's the theory. |
kill your car and coast through them....old trick...and i hear they will send you a ticket in the mail...
There are lots of theories about how to "beat" them, and then I've heard theories about how they can tell if your car magically has no exhaust fumes. I believe that have a sniffer, so the equipment is supposedly "sucking" the fumes. In that case, most car's emissions are worse at idle, so costing through would be worse.
That's all hearsay and BS. Avoid urban freeways and stick with tollways and side streets. Else, get cats and a hotcam. JMO. Ryan |
Yeah they use a sniffer, if you look in the pic you can see it sitting on a tripod thing on the right side of the road. Shutting the car off and coasting through would be a good idea. I don't see how they could send you a ticket if your car isnt registered in that county and if your car is registered in a non-emissions county.
The machine beams infrared and ultraviolet light through the exhausts of passing cars. |
Just kill it. What are they going to send you a ticket for? No emissions?
They are looking for high emissions. |
Don't kill it and coast. They don't like that. Just go down to the next on-ramp. Problem solved.
Originally Posted by whitehooptie
(Post 4215981)
Originally Posted by 69gto96z
(Post 4215119)
Because this system uses a light beam or beams, if there is no exhaust then there is nothing to read.
and then I've heard theories about how they can tell if your car magically has no exhaust fumes Just go down to the next on-ramp |
Originally Posted by Z28SORR
(Post 4217070)
You can't go to another ramp if you don't know it's there!!! What are you going to do stop and back up.
If you can't see what an 1/8th mile up the road on the on-ramp, then you don't need to be driving. They have 50 million orange cones out there and a van parked on the side of the on-ramp. And on a side note, I even know WHERE they like it. :D ;) |
