97 Chameleon Trans AM F/S with TONS of mods!!!
Old Apr 18, 2003 | 08:02 AM
ucrazymonkey's Avatar
1997 PONTIAC TRANS AM
GM CHAMELEON GREEN/BLUE
T-TOPS
FULLY LOADED
LEATHER INTERIOR
*ENGINE:
LT1 PRO EDIT OBD1
VALVOLINE SYNTHETIC OIL
STOCK 5.7 LITER 350 ENGINE
MOROSO COLD AIR INDUCTION
TAYLOR OCV 8MM WIRES
BOSCH PLATINUM PLUGS
MEZIERE ELECTRIC W.P.
JET TB AIR FOIL
1LE ELBOW
HYPERTECH 160 STAT
HEADS: LT1 ALUMINUM
RESURFACED AND CLEANED
NEW VAVLE GUIDES
1.94 I. SBI HIGH-FLOW STEEL
1.50 E. SBI HIGH-FLOW STEEL
1.6 SUMMIT RR'S 7/16 STUD
SUMMIT GUIDE PLATES
COMP CAM 5/16 PUSHRODS
CRANE SPRING REATINER SET
10308-1 CRANE SPRINGS
HARDENED SEALS AND LOCKS
ARP HEADS BOLTS
ARP SCREW IN STUDS
FELPRO GASKETS
*TRANSMISSION:
10" TCI STREET FIGHTER,
STALL CONVERTER
TRANSGO SHIFT KIT
ENEGRY SUSP. TRANNY MOUNT
ENERGY SUSP. TRQ ARM BUSHING
REBUILT A4 TRANNY
RAYBESTES CLUCTHES
RAYBESTED BANDS
SUMMIT 19,000 COOLER
MOBILE ONE SYNTHETIC
LS1 ALUMINUM DRIVESHAFT
BMR DRIVESHAFT LOOP
*REAR-END:
GM MOTIVE 3.73 GEARS
ROYAL PURPLE SYNTHETIC
*EXHAUST:
HOOKER SHORTY HEADERS
CERAMIC COATED
94/95 STYLE SINGLE CAT
FLOWMASTER Y-PIPE & S-PIPE
3" EXHAUST TO CUT-OUT
FELPRO GASKETS
ARP HEADER BOLTS
FLOWMASTER 80 SERIES
SUMMIT 3" CUT-OUT
*WHEELS:
15 X 3.5 WELD DRAGLIGHTS
15 X 8 WELD DRAGLIGHTS
165 X 15 SKINNIES
26 X 10.50 X 15 E.T. STREETS
*SUSPENSION:
BMR TUBULAR LCA'S
BMR BOXED SFC'S
BMR RELOCATING BRACKETS
R/R DRAG AIRBAG
V6 SPRINGS
*MISC:
PRO FORM SHIFT LIGHT
Car has 114,xxx miles on it. EVERYTHING listed above has been done since April 02 with most being done since last Nov.02. I have spent over $5500 since then. The Welds with the ET Streets and skinnies have been to the track twice. I also have the stock 16" TA Wheels with 245/50/16 Tires in great condition. The tranny was done back on April of 02 so there is 14,000 miles on a totally rebuilt tranny. All items above were brand new prior to installation. I will sell everything for $9995. I will seperate the LT1 Edit with OBD1 PCM and install the OBD2 PCM back in and knock off $400. Also I will seperate the Welds for another $800. So if you dont want the Welds or LT1 Edit the price would be $8795. I will ONLY sell the LT1 Edit and Welds if the car gets sold first and the buyer does not want them. The blue book on the car is $8700. Thats $95 for all the mods I installed.
Final Price- $9995
W/O LT1 Edit, Weld Wheels- $8795.
Prices are firm and well worth it. Contact me at ucrazymonkey@cs.com
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Russ95Z28
Apr 23, 2015 01:55 PM
dalynchmob
Feb 19, 2015 07:20 PM
