Y Dos Every 1 Say That V6 3.4
Old 03-18-2008, 07:46 AM
cesar305's Avatar
IS SO BAD TO HOOK IT UP..THAT I SHUD JUST GET THE 3.8 OR THE V8 5.7 CUZ I WAS GOING TO Superchargers MY 3.4 CUZ ITS TO MACH TO TWIN TURBO
cesar305 is offline
Old 03-18-2008, 07:53 AM
dangalla's Avatar
wow
dangalla is offline
Old 03-18-2008, 07:57 AM
Ekof96Z28's Avatar
It isnt that you shouldnt... it just takes more to get anything out of them. Often times it is more economical to just sell it and get a car with an engine that responds better.
Ekof96Z28 is offline
Old 03-18-2008, 08:00 AM
2000GTP's Avatar
There are just better platforms out there to work with. I don't know what kind of aftermarket there is for the 3.4, but if you are talking about boosting it, you are going to have to look into upgrading alot of different things depending how crazy you get with it.
2000GTP is offline
Old 03-18-2008, 02:56 PM
SupplySgt.'s Avatar
you can do what you want but I wouldn't recommend it. It will cost you more in money and time to get the 3.4 to perform than it would to just drop a 3800 series or a 350 in it.
SupplySgt. is offline
Old 03-18-2008, 04:52 PM
Frans96SS's Avatar
Was that english?
Frans96SS is offline
Old 03-18-2008, 05:02 PM
Super Moderator
JakeRobb's Avatar
Please turn off Caps Lock when you're posting. Also, please write in complete sentences and give us as much information as you can about your car and what you want to do with it. It makes it much easier for us to know how to help you.
The 3.4L V6 that was used in the 1993-1995 Camaros and Firebirds is weak and doesn't generate much horsepower, especially in the higher RPM range. Later 3.4L V6's (found in other cars) from 1997 and later have much better heads and intake manifolds, and make quite a bit more power. I've heard of people swapping those parts over to their Camaros with good results.
The 3.8L V6 in the '96+ cars already has some decent heads and a decent intake manifold, so it doesn't suffer from that problem. The performance aftermarket for the 3800 is MUCH broader than for the 3.4.
The LT1 and LS1 V8 engines have huge aftermarket followings and huge performance potential.
Do you already own a car and you are considering an engine swap, or are you thinking about buying a car?
JakeRobb is offline
Old 03-18-2008, 09:00 PM
shock6906's Avatar
I love my 3.4 because even after 15 years and 217,500 miles, it has never been rebuilt or even had the valve covers off, runs fine, and still gets 30mpg on the highway. I don't look to it for anything more than fuel economy though. To think of it as a peformance motor is just laughable.
shock6906 is offline
Old 03-18-2008, 11:02 PM
sn8ke eatr's Avatar
i hope this thread is a joke
sn8ke eatr is offline
Old 03-19-2008, 07:35 AM
cesar305's Avatar
i have a camaro 3.4L V6 1994 i just dont no if i shud swap or shud stay weth wat i gat?
cuz i wood want to Superchargers but dont no if i wood get wat i pay for
cesar305 is offline
Old 03-19-2008, 07:43 AM
2000GTP's Avatar
Personally, I wouldn't supercharge it, I would work with another platform, whether it be buying a different car or swapping in a different motor. What kind of budget are you working with? An engine swap can become costly, buying a new car can be costly, and switching to forced induction will be as well.
2000GTP is offline
Old 03-19-2008, 07:54 AM
Super Moderator
JakeRobb's Avatar
For the cost of a complete supercharger installation, you could probably buy an LT1 Z28, and it would probably be faster than a supercharged 3.4. It would definitely be more reliable. Then add in the money you'd get back from selling your current Camaro, and you're way ahead.
JakeRobb is offline
Old 03-19-2008, 07:59 AM
dangalla's Avatar
guys the correct term here is Superchargers. as in " i would like to Superchargers my car, but i can not afford it. but it is also to mach to twin turbo"
dangalla is offline
Old 03-19-2008, 08:08 AM
Norm Peterson's Avatar
cesar - I realize that you're really new here . . . so I'll go easy . . . and tone it down . . .
If you want to get all of the really good answers, please start asking your technical questions in a less casual manner. Except for posts in off-topic forums, IM-speak, text-messaging, or whatever that communications mess is called these days gives the impression that you might not be smart enough to understand the answers, so people tend to hold back. My eight year old granddaughter writes and spells better than that.
I get paid really good money at my day job, and I'd be insulted if any client ever sent me a request for information or work to be done that looked like that. You can be damn sure that I'd bill him extra for the time it took me to figure out what he said, and then from that what he really meant. I'd make it a separate line-item on the bill so that he would absolutely get the message.
Anyway . . .
On-topic, IIRC the 3.4 was once available in a DOHC arrangement with somewhere over 200 hp even after being downgraded to suit the capacity of the then-available transmissions. I think early testing put it at 270-ish with decent reliability on the test stand. Point being that at least the bottom end ought to be good for an upgrade regardless of the heads and valvetrain, or you might even find the DOHC pieces themselves. If you were to go the DOHC route, I'll suggest investigating for any improvements made for better in-service reliability (it's been a while since I considered using this engine in anything or talked with anybody who was running one).
Norm
Norm Peterson is offline
Old 03-19-2008, 08:17 AM
skorpion317's Avatar
Teh 3.4 Dose Not Have A Lot Of Potentail. Teh Fatest 3.4 Car Was A Turbochargers Firebird Tat Put Out A Lil Ova 300 Hosepowa And Ran In Teh 13's. Full Bolt-on Naturaly Asspirated Cars Run In Teh 15's.
Yo Wood Be Much Beter Of Ether Swapin Teh 3.4l Out Fo A Lt1, Or Selin Teh Car An Buyin A Lt1 Or Ls1 Car.
skorpion317 is offline
Quick Reply: Y Dos Every 1 Say That V6 3.4
