Whats This Plug???
Old Nov 28, 2002 | 12:37 AM
cobra2550's Avatar
Whats This Plug???
ok on a 3.4 engine where the thermostat is its on the right side by that screw on when you take the thermostat,there's some plug there right by the thermostat under the air intake plenum,when I was taking my thermostat off the switch broke and now I got the service engine soon light and when I start my car it shuts off,it starts on the second try but when I let off the gas pedal the engine wants to stall,So I need to know whats that switch for
Old Nov 28, 2002 | 10:49 AM
All_InTheRED's Avatar
I didn't go outside, but I think that is your Cam Position Sensor???
Its in the manifold, not the TB right?
Old Nov 28, 2002 | 02:06 PM
cobra2550's Avatar
yes right by the coil packs and the thermostat,maybe its a Engine Coolant Temperature Sensor
Old Nov 29, 2002 | 07:20 PM
blueirocz-28's Avatar
the cam position sensor is on the pass side of the block, right next to the motor mount, what a bitch to replace also.......
Old Nov 30, 2002 | 12:23 AM
blue95's Avatar
agreed.....doesn't it also have a small ground wire running from the back of the harness?
Old Nov 30, 2002 | 12:51 AM
cobra2550's Avatar
don't think thats the one,the one that I'm talking about is on the drivers side right by the thermostat and it does have the wires
and another ? when I start my car the engine fan would come on right away even if the engine is cold and my service engine soon light is on,Is this my IAT sensor bad
Old Nov 30, 2002 | 01:36 AM
your CTS (coolant temp) sensor is bad.
IAT wont make the fan come on.
Old Nov 30, 2002 | 01:56 AM
cobra2550's Avatar
so thats the coolant temp sensor right by the thermostat right?
Old Nov 30, 2002 | 03:36 PM
yes sir, that be it, make sure you use teflon tape on the threads when you reinstall the new one.
Old Nov 30, 2002 | 04:24 PM
cobra2550's Avatar
Thanks guys I'm going to replace it with a new one
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
