what am i hearing in the back of my car???
i made a turn onto a busy road, and i hear this load noise. Then i started to hear knocking when i was driving. it felt right behind me or right in the middle of the counsole, and it only happens when i go over 25 mph. i looked all on the outside, suspension, and under the hood. i cant really tell whats wrong. if anyone can help please.
Carrier bearing. the V-6's have a 2 piece drive shaft. and to support the middle, they used a rubber mounted bearing. if that goes out the shaft will hit the tunnel. Right now would prolly be a good time to switch to a 1 piece.
1997 Camaro Z-28 6-Speed
1997 Chevy K1500 350/4sp Auto
1994 Mark VIII 4.6L DOHC
1978 Corvette Pacecar 427/6-Speed
2003 Ranger 522SVX 250 Hp (Ordered on 07/28/02 . Changed to the 522DVX on 7/31/02)
2000 Hayabusa
2000 Hayabusa
What year is your car? If it is older than 5 years or so I would also say carrier bearing. Switch to the one piece before is starts to sound real ****y. Besides that the one peice is also a small performance upgrade anyway. Check out www.driveshaftshop.com
Black 94' 3.4l Camaro A4
Could be the trans mount gone bad.
get under the car and when it's cooled down, push up with your hand(use 'some' force) in the DS right behind the yolk (where it exits the trans) if the whole thing moves up, it's the mount
-Steve
1994 3.4L V6 A4
2 - 12" JL Audio 12w6's
JL Audio XR650-CSi (front) JL Audio VR650-CS(rear)
JL Audio 500/1, 300/4 amps
custom box, custom rack, dist block.
http://www.fbody.com/members/v6maro/
www.streetlethalperformance.net - 4th gen f-body car club
-Steve
1994 3.4L V6 A4
I would replace it with a 1 piece, mine went out and started tearing up my pinion seal, causeing me to lose soem differential fluid, causing my rear end eventually blow out. Causing me to upgrade to a 1 piece, 3.42s, LSD, and 4 wheel disc, cutting a few 1/10ths off my time.
Now if its yoru tranny mount, do you have a 5-speed? If so you can physiclly see the shift *** pop a good 1 in. or 3 in the air under load. And it will most likely only make noise under a hard initial loud.
Where a driveshaft will make noise troughtout the RPMS.
Wait was it really that terrible a thing?
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Rapidfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys, 160* stat
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
15s are cool!
AIM: MustangEater82
Best R/T .507
Best 60' 2.106
15s are cool!
AIM: MustangEater82
