What 1/4 mile times can i expect from my Y87 V6?
I am hoping for low 15's with this car. It seems weel set up for drag duty as far as a V6 goes. The 3.42 gears seeem to be great powerband wise for drag racing with this engine. The thing plants you hard in you seat when you launch it and pulls go till the topend
Also i am a very good driver...been drag racing at the local strip since I was 16, so thats not an issue.
check this out http://media.firebirdv6.com/unsunghero.html
In the above article they got a hink if I t15.2 outta a pretty much stock base V6. Stick 3.42's and dual exhuast on and I think I can have 14's. Like I said I am a good driver...I take off the air filter, play with tire pressure...get teh rev RPM's right I can see 15.1. We will see March 1'st
Originally posted by blue95
dang must be nice to have a chance to run low 15's stock...
But even still............. i don't know. Maybe she's gettin old. It's a 1996 with only 45k miles!!
Originally posted by firebirdude
I did not have my cat-back at the time...... so basically stock. My reaction times were between .4 and .9 sooooooo not THAT horrible!!!
Why the hell is my car so slow?!!!!!??!!
if it was .500, or 7 seconds... the 1.4 mile clock doesn't start till you move...
thats why it is possible to have a slower 1/4 time and win the physical, because you had a better reaction time.
What was you 60' and more important the mph your car hit at the end of the 1/4 mile, and the elevation of your track.
Elevation= near sea level....
60ft.= 2.41
1/8et= 11.1
1/8mph= 62.2
1/4et= 17.4
1/4mph= 76.3
So yeah. Pretty darn slow. What's up with that?!?!?! I have an automatic, so it's not the driver!
I have 3.42gears & LSD........ (Y87 package) HELP!!!!!!!!!!!!!!
Whoa when was the lst time you had a tune up?
you mph shoudl be in the 80s....
there is something in your car making it not have full power.
And for the 2.4 60', that could be better, but if you are trapping at 76 mph then your 60' maybe fine, jsut car doesn't have power to pull a better one.
Any SES lights?
when was the last itme you did plugs, and wires. If its been awhile I would do it them and test all 3 ignition coils.
Do you feel the car "stutter", under a constant throttle?
how old is the fuel filter?
when was last time you replaced your air filter?
Ever change your o2 sensors, you could be running super rich.
how old is your Catalytic converter could be getting clogged up.
Any funny smells from your exhaust?
I am trapping 10 mph faster then you so that says I am making a significant amount more hp then you are, and I have a modded 3.4L
your car should be at least the low 80s, and that still woudl not be a very could speed for a 96 Y87.
Any SES lights?
Any SES lights?
Any SES lights?
