Valve Cover Gasket Installation?
Old Dec 25, 2006 | 11:33 AM
  #16
oil pan 4's Avatar
The over size TB is over kill for a stock engine.
I would start on the exhaust and work my way forward.
That linked CAI is a cool part.
I made some thing like that for my diesel truck and it helped a lot. I had installed an air filter monitor on my truck, all it does is read the intake and air filter restriction.
The air intake on my truck was so bad it all most read "change filter" (0.5psi restriction) with a brand new filter. So I built a hugely over kill ram air system, problem solved.
Old Jan 3, 2007 | 11:44 AM
  #17
spydercam's Avatar
is your oil hitting your exhaust pipe (i think it is called the y-pipe right after the manifolds)and burning?mine is doing that and i am also wondering where it is coming from.
Old Jan 3, 2007 | 11:52 AM
  #18
2000GTP's Avatar
Yes, that is the y-pipe. Have you checked for obvious leaks, starting with the intake manifold?
Old Jan 4, 2007 | 03:44 PM
  #19
spydercam's Avatar
yes i stuck my hand down the back side of the motor as far as i could and didn't feel any oil leaking.not exactly sure if i am looking in the right spot though.the oil seem to run down the oil pan as well.
what do you think it is?
Old Jan 4, 2007 | 03:47 PM
  #20
2000GTP's Avatar
Possible a rear main seal or the oil pan gasket itself.
Old Jan 4, 2007 | 08:27 PM
  #21
spydercam's Avatar
and here i am hoping you wouldn't say that.
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 29, 2014 04:54 PM
Snoman73
Nov 17, 2014 07:22 PM
