V6 R&D + mods from japan
Old Jan 30, 2004 | 04:18 AM
oil pan 4's Avatar
http://www.gmvsford.com/forums/showthread.php3?t=2438
So far I have
The Saab inter coolers are up frount ( stock).
The 2 small things behind the intercoolers are stock RX7 by pass valves (If you are a ricer that means there "JDM" blow off valves, big whoop).
The throttle body is stock LS1 a with a heavly altered V6 IAC bolted on it.
The upper and lower plenum is from a 2.8 and the intake manifold is from a '94 3.4L camaro.
The heads are from the last 2.8 I killed.
The turbos are stock 2001 Audi VW K03's
Not shown I have most of a set of after market nissan 180Z turbo and intercooler piping, a few RX7 elbows and pipes and a down pipe for one of the turbos (need one more).
Old Jan 30, 2004 | 04:20 AM
oil pan 4's Avatar
More!
http://www.f-bodytech.com/forum/show...&threadid=2702
http://www.f-bodytech.com/forum/show...&threadid=2719
Old Jan 30, 2004 | 11:02 AM
MustangEater82's Avatar
Awesome!
Can't wait to see that thing run!
Old Jan 30, 2004 | 06:42 PM
ImportKILLER's Avatar
Re: V6 R&D + mods from japan
Heyyyyyyyyyy ....first thing I thought was "Hmmm...JDM".
Old Feb 1, 2004 | 01:57 AM
kevin 2.8's Avatar
summer is coming
Old Feb 1, 2004 | 02:45 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
why not run gen 2 or 3 heads?
Old Feb 1, 2004 | 01:19 PM
kevin 2.8's Avatar
i think for less compression -which is better for turbo
Old Feb 1, 2004 | 04:41 PM
oil pan 4's Avatar
I don't run gen 2 or 3 heads because:
The fuel rail, I don't know what it looks like, I need a vac/boost reactive fuel pressuer reg that's also ajustable I don't know what kind the 3x00 engines have, do you?
I got the heads for free.
I can't machine valve spring guides or seats because I think the gen 2, 3 heads have weird looking angled springs and valves.
I also have a fuel rail tap that I need on the camaro fuel rail.
I want to beable to boost a stock camaro short block for now.
How would you put a LS1 tb on a 3x00 intake?
I don't know if I can get forged deep enough dish pistons for 48cc combustion chambers on boost.
I have drilled and taped coolant holes in the intake manifold for the turbos, I dont know if I can do that with the 3x00 intake manifold.
That's all I can think of now.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
CARiD
Jul 7, 2015 08:19 AM
