Turbo or supercharger?
Old Sep 18, 2010 | 02:03 PM
red97rs's Avatar
Ok, I I've 1997 camaro 3.8l v6. It is all stock and I'm looking to give it more power without swapping for a lt1 ( my parents won't let me get a v8 becaus I'm only 16).
1st- which would be better a turbo or supercharger?
2nd- what brand etc would be the best
-thanks
Old Sep 18, 2010 | 02:49 PM
vincerosas818's Avatar
Honestly, swapping would probably be cheaper than strapping a turbo or supercharger on. It would probably almost be a waste of money if you are planning to pick up a V8 alittle later on, just put a nice exhaust on it, an intake system and call it a day. My advice would be to hold out for a v8. its worth it.
Old Sep 18, 2010 | 02:51 PM
this might help as well
https://www.camaroz28.com/forums/sho...d.php?t=363482
Old Sep 18, 2010 | 02:57 PM
red97rs's Avatar
Ok. Well thanks for the advice, but I have looked for a intake for the 3.8l and they don't really make one unless I was to get the ss hood and use a ram air intake. And the exhaust, I have been told that it would sound whiney since it's a v6 unless I used like a glass pack muffler. Also, if I did get exhaust and intake, would I have to it all new when I swapped?
Old Sep 18, 2010 | 02:59 PM
red97rs's Avatar
Also, I have found a supercharger and it adds anywhere from 20hp to 60 ho. For $200
Old Sep 23, 2010 | 10:19 PM
LLYONS92's Avatar
where did u find that supercharger
Old Sep 24, 2010 | 06:45 AM
fbodyrs96's Avatar
ebay chrome intakes is the seller
95-97 3.8 cold air intake
Old Sep 24, 2010 | 01:33 PM
GRIDERMAN87's Avatar
YOU SHOULD find a wrecked grand prix gtp and take the blower and intake from it and put it on the camaro
Old Sep 24, 2010 | 05:55 PM
red97rs's Avatar
I knew it was the same engine and stuff, but I didn't no about the configuration and I didn't no about hood clearance.
Old Sep 24, 2010 | 08:55 PM
Evolution223's Avatar
can you really do this?? I would think if it was this easy someone here or somewhere would be making kits for our cars, they could make a killing, or atleast could have 5 or 10 years ago. I would buy a set-up in a heartbeat if I could get it for under $500. It was really stupid of GM to not make a v6 SC from factory, they were already making them for Pontiacs anyway,, i guess they wanted everyone to buy the V8.
Old Sep 25, 2010 | 09:45 AM
fbodyrs96's Avatar
heres the 1 0f 2 people who have done it. http://www.fullthrottlev6.com/forums...highlight=fits
Old Sep 25, 2010 | 12:38 PM
BC2002SS's Avatar
It would not be worth it to do a top swap into a Camaro. You need heads,intake (3800NA fuel injectors are in the intake and 3800SC are in the heads) fuel injectors and supercharger. The throttle body is pointing at the firewall and sits to high and hits the cowl. With all that you would be looking at 40-60hp.
If you can weld you could do a turbo for not to much money (about $2,000) and make 450-500hp on a 3800 with a good tune.
Old Sep 25, 2010 | 12:45 PM
BC2002SS's Avatar
this must be the other guy.
http://www.3800pro.com/forum/rear-wh...nly-picts.html
Old Sep 28, 2010 | 12:52 PM
you can do it, im plannin on doin it its not hard to switch heads intake and ecu
Old Sep 29, 2010 | 09:06 AM
sasquatch152's Avatar
Turbo Charger
If that is what you really want to do, id go for a turbo charger, they are quite expensive though. they generally produce more power because they arent sapping power from the crank, instead they get it from the exhaust. But yes, really saving money to eventually do a V8 would be your best bet
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
