Trans mount
Trans mount
Hello all. I am getting ready to buy an Energy suspension kit for the camaro. I want to buy the Z28 box cause I plan to put the rear sway bar on at the same time. What I am not sure of is the trans mount the same for a v6 auto and a Z auto? Are there any other differences in the bushing I am not aware of?
Thanks for the help.
that is incorrect, the trans mount produced by ES will not fit on the 3.4L unless you modify the trans crossmember, its not hard, but you will need to drill another hole in the crossmember or lengthen the stock hole. also the poly trans mount is shorter than the stock one , so you will need to rig up some sort of spacer
Jul 4, 2005 05:00 PM
