trans issue 3.8l
i was driving my car to pittsburgh and after the car got hot (around 210 which is where it usually runs) i started to have a trans problem. i was at a red light and it shifted hard from first to second no other gears just first to second. it is an automatic and my dad told me to change the filter and fluid but i was not sure if it was more like the bands or solidnoid but if anyone has more info for me it would be awesome thanks
Re: trans issue 3.8l
210 seems awful hot. My 1997 3.8 usually runs about 180.
you getting any SES codes? could be a a VB issue. its fairly common actually. how many miles of trans? i think the code usually associated with this is 1870. its most likely the TCC PWM control valve wearing it's bore in the valvebody. you can fix this easily by removing VB and reaming new hole. however the reamer is pretty exp. i have seen rebuilt valve bodies on ebay that has the sonnax update already. if it keeps shifting harshly and you do get a ses code, i would bet this is the problem.
Originally Posted by dougefresh
(Post 6664387)
no it doesn't haven't a trans cooler and no its not throwing any codes it just slams into second. i notice it more after longer drives, like after running for an hour it will start acting up. could it be a shift sensor? o and it has 135,000 on the motor and trans
