torque converter?
Old Apr 14, 2003 | 03:35 PM
foshizl's Avatar
torque converter?
i was reading somewhere and they were saying if u get a diff cam that u should upgrade to a 2400 stall converter...
"my question is im going to be getting a cam, and should i get a new converter?" how would it run on the street with it what difference would i notice?
THanks
Old Apr 14, 2003 | 04:57 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
yes you should match your cam to your stall, depending on the specs of the cam (where you will be making the most power) determines where your TC should stall. with a higher stalling converter you will get less MPG, but if you are swapping a new cam in there that will also hurt your MPG, so might as well make the car run fast while its gettin crappy MPG
Old Apr 14, 2003 | 06:03 PM
shortdog273's Avatar
2400 is too small. I wouldn't get no less than a 2800 stall.
Old Apr 14, 2003 | 07:02 PM
chesee48's Avatar
i 100% agree! Anything under 2800 isnt worth it.
i think on a pretty much bolt on car, a 2800 would be perfect, although some like to go a tad bit higher,,
Old Apr 14, 2003 | 08:41 PM
V6Power's Avatar
Think 3200+ man. 3.8s with high stalls are wicked to drive. You'll love it.
Old Apr 14, 2003 | 09:10 PM
That's the stall I'm planning on getting, but if I might go higher if I get a cam.
Old Apr 14, 2003 | 09:18 PM
chesee48's Avatar
What gears you running?
Old Apr 14, 2003 | 09:26 PM
Stock 3.42s
Old Apr 15, 2003 | 11:59 AM
Tuitsui's Avatar
what kind of converter would you recomend for a 3.4?
And does it Harm engine/tranny?
Old Apr 15, 2003 | 01:44 PM
atl2001's Avatar
i would reccomend the stock converter in your car with the current mods, until you start making a decent ammount of power more than stock there isnt much of a point in it IMO
Old Apr 15, 2003 | 03:13 PM
foshizl's Avatar
Question
how exactly does a torqu converter work, because i think my understanding is wrong, i think i get how it works from a standstill, ie (if u had a 3200stall) it wouldnt go till 3200rpm but how bout when it changes gears, , i might be wrong but how do they work?
Old Apr 15, 2003 | 03:50 PM
atl2001's Avatar
www.howstuffworks.com
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
