top 5
Old Apr 15, 2003 | 05:47 PM
raiderman119's Avatar
Talking top 5
what are your favorite mods to v6 camaros/firebirds? appearance and performance....
Old Apr 15, 2003 | 06:11 PM
Tiago's Avatar
performane:
turbo, internal engine mods
appearance:
wheels
Old Apr 15, 2003 | 06:23 PM
94Camaro's Avatar
performance:
turbo, heads/cam, intakes, bigger TB, headers
appearance:
def. wheels
heheh
-R
Old Apr 16, 2003 | 12:49 AM
chesee48's Avatar
1.Gears/Stall for big difference...
2.Catback
3. Lid/Ram Air
4.SFC and if lowered, then: LCA and brackets
5. Gotta go with Wheels! Nothing under 17in!!
EDIT: I think a hood is a HUGE thing too. I hate the stock hoods on 93-97 camaro's.
Old Apr 16, 2003 | 09:29 AM
Bliggida's Avatar
1) Running 15's
2) Running 14's
3) Running 13's
4) Running 12's
5) Running 11's
Old Apr 16, 2003 | 09:40 AM
chesee48's Avatar
Originally posted by Bliggida
1) Running 15's
2) Running 14's
3) Running 13's
4) Running 12's
5) Running 11's
Good answer!
Didnt see that one coming hehe
Old Apr 16, 2003 | 10:16 AM
ImportKILLER's Avatar
1) Intake & full exhaust
2) Rearend & gears
3) Cam
4) NAWS
5) Whatever appearance mods you like...
I don't know if I'd go through the trouble of turbo-ing my Camaro. Now if I had a LS1, I'd turbo that sumb*tch.
Old Apr 16, 2003 | 11:24 AM
MustangEater82's Avatar
Well affordable mods while keeping the car easily streetable...
Exhaust
Intake
Gears/LSD
suspension
Tires
Old Apr 16, 2003 | 04:56 PM
ibanez6rg's Avatar
1) Running 15's
2) Running 14's
3) Running 13's
4) Running 12's
5) Running 11's
Ahhh...If only it twere a mod
Old Apr 19, 2003 | 12:48 AM
97QuasarBlue3.8's Avatar
Performance-- Intake and exhaust. Let it breathe and make music
Appearance-- Tinted windows (nice, dark...not purple K-Mart junk), a really nice wax job, and a good set of wheels on low profile tires.
Old Apr 20, 2003 | 01:02 AM
blue95's Avatar
1. Ripper shifter
2. High flow Cat
3. Wheels and tint....no real order I guess
Old Apr 20, 2003 | 01:21 AM
1fastV6's Avatar
subframe connectors
hood
seats
well these are my fav mods
Old Apr 20, 2003 | 02:28 AM
Bliggida's Avatar
Seriously though,
For me, the most fun I have bolted on, or enjoyed the most were the following...(some still left to install)
These are all for getting the car to hook up and go fast in a straight line.
1) 1-Piece Driveshaft, I got stock steel, but if you can - get aluminum!!! You'll drop 12 pounds off your driveline!
2) Short Shifter (for T-5)
3) Posi-traction (and gears - 3.42's, 3.73's, or 4.10's)
4) Subframe connectors
5) Lower Control Arms (and/or Torque Arm)
So it's actually 7 pieces instead of 5. But when all combined, especially if you are running 275mm or wider tires. You'll pull just about anything off the line, even if you lose on down the track. You'll run at least 14.5 with that setup, and you're running that fast through the stock intake and exhaust!!!
With ram air, and a full exhaust, you can expect to run low 14's.
The only thing I plan on adding is a big camshaft. And I expect to run high 13's when done - with no other engine work.
Old Apr 20, 2003 | 08:38 AM
2000camaroRS's Avatar
which gears should i look at, the 343 or 375s??? which is better for city use and pwer??
Old Apr 20, 2003 | 02:19 PM
3.42s. They come stock on our cars with the Y87 option. Some say 3.73s are good too but I do a lot of highway driving, so 3.42s were better for me.
