temp sending unit/pcu sender
Old Dec 19, 2003 | 03:49 AM
user name's Avatar
hello, i am a newbie here. gotta question about cooling system electronics. my g/f has a 94 camaro (3.4, auto). the fan doesnt come on til about 230* according to the gauge. i know they are s'posed to come on high, but is that right. i dont know if that is right, if the sender for the gauge is bad, or the sensor for the computer is bad.
can someone tell me where the temp gauge sender is and where the computer/fan switch is (i think one is down on the drivers side front of the block and one is on top of the engine).
i am thinkin of running a switch from to the relay trigger to activate the fan whenever. ive seen the kits for a lower temp fan sensor and they are pricey. any other alternatives (for a fan switch)..... and once its on, the car cools down real quickly.
i dont want to start throwing money at sensors, so all help is very much welcome. thank you all in advance.
Old Dec 19, 2003 | 07:01 PM
oil pan 4's Avatar
You could put in a switch that would not be to hard.
Old Jan 17, 2004 | 09:38 PM
Eliminator's Avatar
Run a colder thermo. 160 degre. Also you could make your own switch to turn your fans on when ever you want.
Old Jan 18, 2004 | 02:24 PM
user name's Avatar
thank you. im gonna leave the 180 in for now till summer. i want to see how it runs when its hot out. i was really lookin for a way to close up the desparity between the stat opening and fan coming on (on most cars, normally fan comes on ~20* over stat opening, and off ~10* over stat opening. i.e., in this case with a 180, fan would come on at 200, off at 190).
i wanted an adjustable fan controller, so if i swap stat temps at some later point, i can dial in the switch where i want it.
gotta question for you. on this car, whenever the HVAC controls are at any setting except for the setting for just upper vents or just lower vents, the fan comes on. does this sound right? yours do the same?
she usually has the a/c or heater or defroster on, which would make the fan be on anyhow. at a minimum, i will do a manual switch.
thanks for all the ideas, keep 'em comin. :-)
jhaase
3rd Gen / L98 Engine Tech
20
Oct 4, 2015 05:10 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
Jul 10, 2015 02:23 PM
Jmj93z28
Jul 8, 2015 10:01 PM
