Speedometer recalibration?
Old Mar 21, 2012 | 10:46 PM
sick94's Avatar
I have a 1997 Pontiac Firebird 3.8L M5 with a Y87 rearend that I installed. Stock gearing ratio was 3.23, now its 3.42's. How do I go about recalibrating the speedometer so that it's correct? What are my options? I read that you can use a Hpertech Pro tuner but I cannot find one, not even on their website. I also found PCMforless which charges $150.00 to flash the pcm. Any other options or does anyone know where I can find a hptuner to correct my speedometer?
Old Mar 22, 2012 | 01:37 AM
ImportKILLER's Avatar
Re: Speedometer recalibration?
If you plan on doing some other modding, go the PCMforLess route as they can factor all that in when they tune a new PCM.
I did that when I put on headers, LSD & new rear gears. Worked like a charm.
Old Mar 22, 2012 | 07:31 AM
Wild Willy's Avatar
Yes, you need to re-program your PCM. A decent speed shop, that tunes these cars could probably do if for you more cheaply than buying a Hypertech. You can also have it calibrated for non-stock sized tires.
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 12, 2015 10:12 PM
jimlab
16
Dec 24, 2002 09:39 PM
XthHawk #021
Middle Atlantic
Dec 3, 2002 02:44 PM
