94 retiming
Old 02-10-2015, 09:15 AM
indiana115's Avatar
94 retiming
Does anyone have an idea the cost to have my motor retimed at a repair shop?
indiana115 is offline
Old 02-10-2015, 10:31 AM
indiana115's Avatar
Re: 94 retiming
Replaced head gaskets and threw the rockers out of time in the process. '94 w/3.4 v6 motor
Old 02-10-2015, 12:33 PM
Re: 94 retiming
The only way you could do that is if you misaligned the timing chain, or somehow installed the crank and/or cam position sensor incorrectly. Are you sure you have the spark plug wires installed on the correct coil/cylinders? Valve lash set correctly?
Injuneer is offline
Old 02-10-2015, 04:48 PM
indiana115's Avatar
Re: 94 retiming
When i replaced the gaskets i took the heads apart to clean them up and mistightened to rocker arm nuts. i need to get them properly tightened and would rather a pro do it than continuing to adjust them myself and possibly making the problem worse
Old 02-10-2015, 06:25 PM
Re: 94 retiming
Then it's not a valve timing problem, it's an adjustment problem. I suspect a shop would charge you 2 hours of labor to adjust them..... $150 - 200 depending on you local rates. Maybe less than 2 hours if they are honest.
Injuneer is offline
GSS9909
49
01-14-2009 10:54 AM
SunsetHawkSelena
13
11-12-2008 02:57 PM
pv2hodge68x
05-27-2008 10:58 PM
Quick Reply: 94 retiming
