Since I can't post on camarov6.com yet.. trans question
Old Nov 17, 2006 | 01:34 AM
mmmchickenboy's Avatar
I've got a little engine swap project going on and I am using a L67 S/C 3.8L engine, but I don't know what transmission to use. Factory L67 hp is ~240-250ish, and I would like about 300hp. I've been doing some reading and it seems the V6 camaro 5sp is WEAK, even at stock N/A 3.8L power levels. I completely despise automatic transmissions in sports cars. But the only RWD manual trans that bolts up to a 3.8 is the camaro 'box (or is there an S10 'box I'm not aware of?). The only way I can see myself using an automatic is with a full manual valve body, but shifting from 4 - 1 at every stop will suck. Another question I have is : is there a stronger transmission that I can bolt up to a V6 camaro 5sp bellhousing? Is the V6 camaro bellhousing even removable? I'm hoping a ford V8 (or V6 I guess.. if it's stronger than a GM V6 5sp) will bolt up to the V6 5sp bellhousing. I highly doubt the ford V6 5sp is any better than the GM 5sp, they're probably the same 'box. I'm also going to assume that a T56 has a 0.001% chance of bolting up to a 5sp bellhousing.
ok.... annd... GO!
Old Nov 17, 2006 | 11:07 AM
camaro862gcj's Avatar
Check out G-Force transmissions. There has been a lot of talk about them for upgrading t-5's. I don't know if you're willing to spend that kind of money, but I believe that is your only real option.
Old Nov 17, 2006 | 07:57 PM
NOS2006's Avatar
Well, FWIW, everybody says an L67 swap into a Camaro isn't possible without some pretty big modifications to fit the L67 in there.
Old Nov 18, 2006 | 01:18 AM
well its a good thing im not talking about a camaro then or any other GM chassis for that matter..
Old Nov 18, 2006 | 12:55 PM
Wolfie's Avatar
nobody has ever tried it, so the "it wont fit" claims have no basis
from my mesurements the sc is only 1/4 of an in taller than the n/a intake
you would have to fab up 2 elbows to point the tb and the thermostat to the front of the motor, and the fuel line would need some modding
Old Nov 21, 2006 | 06:39 AM
MustangEater82's Avatar
I swear people have tried it and it doesn't fit in 4th gens...
as for transmissions... Look up a guy named Linx on www.fullthrottlev6.com (another v6 board) I believe he is pushing like 400 hp on a 5-speed, he either had his stocker built stronger or upgraded.
You could probably drive around awhile with a stocker v6 5-speed, if you just want it to get your project on the road, just ease into the throttle and don't shock like hard shifts while racing, and it should hold up.
I have broken a few, but almost all are racing related. There are people that have several passes on juice which is probalby in the 300 hp range.
I think people were getting built trannies for like $1-1.5k
Old Nov 21, 2006 | 10:12 AM
AlfredB18's Avatar
Really?
http://www.fullthrottlev6.com/forums...ad.php?t=10360
"Reasons why you can't easily put a GTP m90 on an F-Body. Now STFU!"
Old Nov 21, 2006 | 11:19 AM
Wolfie's Avatar
Originally Posted by AlfredB18
Really?
still just words, nobodys ever tried it, un till I see a pic that shows it wont work, I'm gonna belive what I have personally mesured
http://www.firebirdgt.com/SC%20Firebirds.htm
oldschool
Feb 9, 2016 09:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 13, 2015 09:52 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
