shocks
Old Nov 28, 2003 | 07:28 PM
dbzmatrix's Avatar
shocks
is it fairly easy to replace the shocks? i'm gonna change all 4 cause it's a '96 and as far as i know they've never been changed. also, what kind do you guys recommend buying? thanks for any help.
Old Nov 29, 2003 | 04:20 AM
ImportKILLER's Avatar
Rears are easy. Fronts are a major pain. I seriously hope your 96 isn't a nightmare like mine were...front mounts were toast.
I went with Bilsteins (found them cheap online). If you don't have the $$$ for them, some take-offs will last you another 30-50k.
Old Nov 30, 2003 | 10:15 AM
94camaro34's Avatar
fronts are horrible....my mounts were bad so i had to replace those...i think they were like 110 each...and then the STRUTS in front were another 150 or so all together....rears should be fairly easy though....try to spray some penetrating oil on all the bolts for a few days before you do the job...helps big time when you go to do it
Old Dec 1, 2003 | 05:40 PM
dbzmatrix's Avatar
so the V8 take-offs from slp will fit on our cars? i found these on their website and was wondering if that was the right thing to get...thanks again.
Old Dec 1, 2003 | 05:50 PM
Those are the ones. Don't expect significantly better performance...more just a suitable replacement. Unless of course, if your current shocks are BAD then it will be better performance.
My take-offs are in the box sitting in my garage collecting dust, still in the SLP box.
RUENUF
Mar 13, 2016 03:37 PM
karpetcm
Dec 16, 2015 09:07 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
