Is this the schrader valve? Is this rust ok? Should this be plugged in?
Old Feb 27, 2004 | 01:23 PM
BradleyPeart's Avatar
Question Should this be plugged in here? Is this rust ok?
EDIT: Changed my topic since I found the schrader valve.
Check page 7 of my webpage for pics of my problems (The red button at the bottom of this post).
While I was looking for the schrader valve, I noticed alot of rust, is this normal?
Just behind this rusted part- a plug that is not plugged in. I don't see any obvious place that it should go. Any ideas?
Old Feb 27, 2004 | 02:56 PM
J0HN D's Avatar
Nope, that's not the schrader valve. The schrader valve is on the passenger side, and it's got a black cap on it. It will be sticking up from the fuel rail between the first and second injector. I have a picture on my webshots page, under the nitrous install folder.
http://community.webshots.com/user/johnduncan10
I don't know what that connector is, but it's not supposed to be hanging there. It looks like it would reach your abs box. Check to see if it goes there. My car is not here, so I can't go look on mine right now....
Old Feb 27, 2004 | 06:18 PM
Originally posted by J0HN D
[B]I don't know what that connector is, but it's not supposed to be hanging there. It looks like it would reach your abs box. Check to see if it goes there.[B]
Could you point my in the right direction of my abs box?
Old Feb 27, 2004 | 06:46 PM
I think I found it. look again at page 7.
EDIT: Picture 2.
Old Feb 28, 2004 | 11:29 AM
I am going to go plug it in to there now. I don't think it could possibly go any where else.
What does having this unplugged do? Was this dangerous? Should a light have come on as a result of it?
Old Feb 28, 2004 | 06:15 PM
J0HN D's Avatar
That's the master cylinder. Looks like the wire belongs there. It is either a low fluid warning, or it is a warning that the brake pressure is not adequate (usually due to a leak or no fluid). So it was ok for now, being unplugged.
The abs box is a little further down, it has the brake lines running in and out of it.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
Cam28_boy
Aug 6, 2002 08:40 AM
