Schrader valve
Old May 19, 2007 | 11:17 AM
copboy736's Avatar
Schrader valve
Where is the Schrader Valve on the 3.8 engine? Is it the green cap that is on the fuel line? The cap has a tag on it that says evap service port. I dont see anything else around the fuel lines that could be it, but I am afraid I am going to relieve pressure to the wrong thing.
Thanks guys
Old May 19, 2007 | 02:36 PM
2000GTP's Avatar
No, that is not it. It should have a black cap and it is going to run off the fuel rail itself.
Old May 19, 2007 | 03:38 PM
FunkZ's Avatar
It sounds like what you found is the valve for the A/C.
Old May 19, 2007 | 06:47 PM
Don350k's Avatar
He found the Evap system
Don
Old May 19, 2007 | 08:45 PM
copboy736's Avatar
Thanks for the replies guys. I needed to find it to change my fuel filter. I just changed the filter without releasing that pressure. It didnt even put out that much gas when I changed it out.
It is all done now, thanks.
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
