resetting obd1
Old Sep 22, 2010 | 07:56 PM
CAMBURT's Avatar
resetting obd1
how to reset obd1 computer on a 94 v6 camaro. any help would be appreciated.
Old Sep 23, 2010 | 08:27 PM
brandons94lt1's Avatar
Now by reset do u mean clear the codes and the learned fuel curve? (If that applies to the v-6 cars) do u have ur owners manual? There's a fuse that is for the ecm, pull it for a few moments, or disconnect your + battery cable for 5-10 mins. Now if u mean u had the ecm tuned, don't know if they can do that on a 93, I think a 93 is an eprom, and any tunning would be done via a chip that's connected to the ecm. But incase I'm wrong, if u had the ecm tuned and it was more than a flash tuning, it would have to have the stock programing put back on it. I may be wrong, as far as the eprom, but I don't think I am. Easiest way is pull the fuse, owners manual will tell u which fuse. Hope this helps.
Old Sep 23, 2010 | 08:30 PM
Sorry, I'll learn to read one day, a 94 is not an eprom. As such pull the fuse or disconnect the + batt cable. Same goes for the ecm if u sent it off for programing. Would have to have stock tuning re installed.
whitehooptie
Aug 10, 2015 07:02 AM
surreybrad
Jul 29, 2015 02:55 PM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
JonCR96Z
Advanced Tech
10
Oct 19, 2002 10:42 PM
