rear end swap
Old Apr 21, 2004 | 10:35 PM
crasher88's Avatar
rear end swap
right now I have a 94 v6 camaro with a stock 4 speed auto tranny and rear end. What I would like to do is replace the rear end with an 02, or simmiale read end setup, v6 rear end. I want it for a few reasons one I will finnaly have 4 wheel disk breaks, a limited slip differential and a new rear end with less miles. But are they replaceable can I change them out with ease. And where should I replace them should I take the drive saft and replace it from there back our should I leave my old drive shaft and just replace the rear end. And if it is possible can you post a link to a how to for replaceing it.
ps
forgot there was a drivetrain subforum. Sorry to all the modorators feel free to move it if you like. Sorry again
Old Apr 22, 2004 | 07:20 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
dont worry about the placement of the post, i can tackle it for ya
first off , you have 3 channel ABS if you want your rear ABS to function properly and not have a flashing light on your dash all the time you will need to get a rearend from a car that does not have traction controll (the traction controll cars rear brake system is different, it will work mechanically , but your rear ABS will not work)
also right now you have a 3.23 gear in your rearend, if you get a rearend from a 6 speed you will have a 3.42 gear (better for acceleration, however unless you get your car tuned for the gear your spedo will be off by 1.15 % (if i recall correctly))
so if you dont want to deal with that look for a rearend from an automatic
as far as the D/S goes.. yeah i would replace it, the stock one is a POS
when changing rearends, all you need to do is jack up the car, disconnect the brake lines, the E-brake lines, the LCA's the panhard rod, and the shocks and it should come out (unless there is a ton of rust everywhere like there was on my car (it took me 2 days of bitchin and moaning.. but i also ended up breaking a few bolts and it was really cold in my garage so i was moving slow.. with no rust and a warm day it should take an afternoon)
reply if you need any clarification on anything
Old Apr 23, 2004 | 12:13 AM
crasher88's Avatar
thanks man but I got a few questions
how can I tell if it has traction controle on the car. Does it have that second gear start button in the cab of the car.
and what is the panhard rob. I have a service manual for my year camaro and I can't find anything about that.
and will my wheels from my camaro fit on the new rear end are the wheel studs the same distance apart or will I have to replace them or modify them some how
but thanks for the help with your advice and my book I can probably do it in my drive way once I find one in good shape.
Old Apr 23, 2004 | 10:29 PM
atl2001's Avatar
the panhard rod is the lil u channel peice of stamped steel that goes from the body to the rear axle..
if the car has traction control it will have a TCS button , SGS is totally different (SGS will not affect the rearen
if your wheels fit on your current rearend they will work on a new one as well
Old Apr 23, 2004 | 10:33 PM
crasher88's Avatar
thanks man now ist time to find one that is in good shape
Old Apr 24, 2004 | 12:29 PM
atl2001's Avatar
no problem, and good luck
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
