Rear end
Old Mar 5, 2004 | 07:48 PM
RS96Silver's Avatar
Rear end
I got a 96 RS. Does any1 know what gears i have in?
Old Mar 5, 2004 | 08:30 PM
tdaddyz's Avatar
if auto 3.08 unless u have y87 then it's 3.42's, if manual then u have 3.23
Old Mar 5, 2004 | 10:20 PM
RS96Silver's Avatar
i have a manual so having 3.23 in there does that mean that i have limited slip or...? i got no clue on anythin with rear ends
Old Mar 5, 2004 | 11:08 PM
oil pan 4's Avatar
You most likely have an open diff.
PRO code Y80 or some thing "80" is the LSD code.
Old Mar 8, 2004 | 06:11 PM
camaros_4_lfe's Avatar
light em up and find out...lol j/k yeah look for the code
Old Mar 21, 2004 | 08:03 PM
RS96Silver's Avatar
alright so i was all thinkin that i had a 1 wheel peel....so i was outside of work and i was talkin with my buddy....he takes off side ways so i rev it up and pop the clutch....i went back to work the next day and i left two strips....i was confused cuz every1 has told me i couldnt
Old Mar 21, 2004 | 11:53 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
its possible to spin both tires with an open diffy... are your tires getting bald? or was it on asphalt? i used to spin both tires all the time when it was wet out and i had the open diff..
if you want to know for sure, jack the rearend up and spin one of the wheels , if the other wheel turns the same direction then it has an LSD.. if it turns the other way then you have an open diff
Old Mar 22, 2004 | 08:58 AM
RS96Silver's Avatar
i did it on dry pavement...and ive had he tires for about 10,000 miles so they arnt in that bad shape
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
