Rear end
alright so i was all thinkin that i had a 1 wheel peel....so i was outside of work and i was talkin with my buddy....he takes off side ways so i rev it up and pop the clutch....i went back to work the next day and i left two strips....i was confused cuz every1 has told me i couldnt
its possible to spin both tires with an open diffy... are your tires getting bald? or was it on asphalt? i used to spin both tires all the time when it was wet out and i had the open diff..
if you want to know for sure, jack the rearend up and spin one of the wheels , if the other wheel turns the same direction then it has an LSD.. if it turns the other way then you have an open diff
