question about plug wires
Old Nov 20, 2003 | 08:29 PM
dbzmatrix's Avatar
i've read a lot of stuff saying that the plug wires on the 3.8L go out all the time....my car has been cranking a lot before getting started and has had kind of a rough idle to it too....nothing too bad, goes away when you start accelerating. just wondering if this could be bad wires, thanks.
Old Nov 20, 2003 | 11:03 PM
ImportKILLER's Avatar
Post
Only way I know for sure wires are bad is if I can see them arching.
Doesn't sound like wires...you can always use better wires than stock ones though.
Old Nov 21, 2003 | 12:31 AM
dbzmatrix's Avatar
any chance it could be the plugs then? the battery should be good, i had the starter tested and it was good, new alternator, new fuel pump, new fuel filter...what else could it be?
Old Nov 21, 2003 | 01:14 AM
It COULD be the plugs. It COULD be a lot of things.
How long ago since you last replaced the plugs and wires? If it has been a while, you could always replace them since they would need to be anyways. You might get lucky and solve your problem.
Is your car throwing any codes (SES light coming on)?
Old Nov 21, 2003 | 03:25 PM
dbzmatrix's Avatar
i think the plugs and wires were both changed a little less than 30k miles ago, so i'm not sure if it could be those. no, it's not throwing any codes, so who knows.
Old Nov 24, 2003 | 02:29 PM
96 camaro 4 life's Avatar
Is that true about the 3.8's plugs going often?? I changed my plugs and wires and then one year later i had to do them again. I wasn't sure if it was just crappy plugs or if there was something wrong with my car. The mechanic couldn't really give me an answer.
Old Nov 24, 2003 | 11:26 PM
dbzmatrix's Avatar
yeah, from what i've read the plug wires on the 3.8's wear out fast...click there to read a guy's thread talking about the supposed wire problem
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
