power windows
Old Oct 10, 2006 | 09:57 PM
94 Green Machine's Avatar
power windows
i no this isn't about the v6 but mines a v6 so i'd though i'd ask lol anyway my power windows they will some times just stop workin and i'll wait a bit and they'll work again and this dosen't happen often just every onec in a while any of your guys/gals havein this same problem and how can i fix it
Old Oct 11, 2006 | 09:19 AM
Ryder4864's Avatar
Re: power windows
You need new window motors. I had the same problem with them going up and stopping, then waiting and they'll go up again. You need to get new motors. I found a great site on the internet that will show you how to install them yourself. It requires taking your door panel off, drilling out certain parts to access the rivets, then drilling out the rivets. Finally, once the old motor is removed, you can bolt in the new one and hook up the wiring. It took me abuot 2 hours to do it. I'll try to find the website that I used and post it later. Take care and good luck!
Old Oct 11, 2006 | 09:20 AM
Ryder4864's Avatar
Re: power windows
http://shbox.com/page/windowmotor.html This is the site that I used. It was very helpful. Hope this works out for you!
Old Oct 11, 2006 | 11:54 AM
lucky19's Avatar
Re: power windows
Ditto, your motor it telling you its fixing to go out. Autozone has them fo 50 bucks i think and they come with lifetime warranty. Just buy one and when the other side goes out take it back and say you have lifetime warranty on it. No need to buy two if its the same motor.
Old Oct 11, 2006 | 02:21 PM
2000GTP's Avatar
Re: power windows
Yeah, definitely follow Shoebox's guide, I had both doors done in around an hour. Its not as daunting of a task as it may look.
Old Oct 12, 2006 | 08:44 AM
Ryder4864's Avatar
Re: power windows
Yeah, I bought a motor at Autozone and it was lke $57 total and has a lifetime warranty, but only for one motor. It works just fine.
Old Oct 12, 2006 | 10:00 AM
01Z's Avatar
01Z
Re: power windows
These motors can be made to work again. I took mine apart, cleaned and replaced the lubricant and circumvented the thermal bi-metal resistor. The lube inside these motors is not grease. Whatever it is resembles a sticky substance that has a weird adhesive quality. It was thick, stringy and difficult to wipe clean. I don't know how "worn out" is actually defined but the brushes and commutator on my driver side motor were quite fine but the motor could not move the window the full extent without resting. Cleaned, re-wired and greased, including the modulator assembly and the 12 year old motor now does everything I ask of it.
Keenan
Jan 19, 2023 12:24 PM
1996LT1Z28
Jul 20, 2015 02:00 PM
capebuf
Jan 13, 2015 07:22 PM
XtremeLt1
Sep 13, 2002 08:50 PM
MilkyClr69
Jul 29, 2002 10:01 AM
