polished heads
Old Jul 28, 2003 | 01:42 AM
NTR89camaro's Avatar
polished heads
i ahve a 89 rs 2.8 v6...if i port and ploish the heads, would it make a good difference?
Old Jul 28, 2003 | 09:40 AM
camaros_4_lfe's Avatar
if you have an exaust and free flowing intake you will prob notice about a 20 hp difference maybe slighty more
also dont forget the 3 angle valve job
Old Jul 28, 2003 | 11:57 AM
2turboz28's Avatar
you will see a big difference if you have someone that no's how too port do it. people that do it for a living (like myself) no how much and where too take material out. good luck!!
Old Jul 28, 2003 | 12:52 PM
1fastV6's Avatar
like that is an easy job!
Old Jul 28, 2003 | 01:08 PM
CARdiac's Avatar
Ok, so are you going to hook some of us 3.4s up with a post polish and valve job?
Old Jul 30, 2003 | 02:46 PM
viper98885's Avatar
Porting and polishing your heads will actually slow down the air velocity into the combustion chambers due to the increased volume. While the air will flow smoother due to the polished runners, it does not flow as fast. You should seriously think about putting a cam in, even a mild one, if you P&P yours heads. You will gain a very good amount of power with the combo and it's easier to get it all done in on sitting rather than two seperate jobs.
Dmonty
Jun 2, 2015 11:19 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
thenewkid
Nov 27, 2014 09:41 AM
