Please any help would be great =/
Old Aug 7, 2009 | 09:48 PM
zackthespaceboy's Avatar
Question Please any help would be great =/
I have a 1991 3.1 v6 camaro RS and it wont start.
I moved it for street cleaning one day and then next it didnt start at all.
The engine cranks but thats it, it did start up a few times and ran for about 15mins till it died and that was the 1st time it started in 3months since it stopped running....
But now it just does not run, only cranks up, anybody know what the problem could be??
Old Aug 8, 2009 | 03:32 PM
mdenz3's Avatar
Check your fuel pressure.
Old Aug 9, 2009 | 11:52 AM
Ok ima do that but this other dude said it could be the timing chain..is that true?
Old Aug 10, 2009 | 09:44 PM
SupplySgt.'s Avatar
it's possible but you need to start with fuel pressure cause if it's your fuel pump then that's a much easier fix. you want to start with the simple things before you start going after other possible problems.
Old Aug 12, 2009 | 05:01 AM
chevycamaro210's Avatar
check to make sure your getting spark. if so then check fuel pressure if your getting both then it might be timing.
Old Aug 12, 2009 | 09:39 AM
Thank you for the help, now ima have a go at the fuel pressure and hope the the fuel pump is the problem lol
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PROJECT X
Apr 17, 2015 12:13 AM
gto4u2
Mar 14, 2015 06:05 AM
cmyname1
Feb 16, 2015 08:33 PM
