Pictures of the V6
Old Dec 24, 2003 | 12:18 AM
oil pan 4's Avatar
Pictures of the V6
Click on this>(.)(.)
Old Dec 24, 2003 | 04:45 AM
kevin 2.8's Avatar
wahooo! *****! er
finnaly pics of the car
wow man thats awesome i could see youin the reflection of the pic of the valves, you took that pic in the kitchen
did you bevel into the middle of the valves?
you say you used a drill press, did you use a dremel at all or a hard carbide bit?
im thinking about doing this to my limo now, it needs a swap soon.
did you take the engine top off a parts/scrap car or the ones right off the car you are putting the motor in. and you did buy new valves? did you buy springs?
Old Dec 24, 2003 | 06:43 AM
oil pan 4's Avatar
The 2.8 heads were off the last 2.8 motor I trashed.
Those were the orignal sh!ty used stock valves. I have kmotion k-700 springs for the heads.
The only still pic I have of the V6 is of it all covered with mud with the stock rally wheels on the frount and s-10 wheels with tires I was burning up on back.
I have more pictures to load It just takes so long to up load each one.
I also have more pictures to take.
Those mirror like combustion you saw are about done.
All I used was sand paper on the valves.
Old Dec 24, 2003 | 09:08 AM
kevin 2.8's Avatar
abusing your camaro
are you going to use a manual water pump or an electric?
ive read here electric ones free upwards of 10hp
Old Dec 24, 2003 | 09:11 PM
oil pan 4's Avatar
I have never seen a 12v water pump for a 60*V6. If I say on I would most likely buy 1 or even 2 so I could have an extra one.
Old Dec 25, 2003 | 02:52 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
404 Error - File Not Found
The page or file you are looking for (http://camaroproject262.cz28.com/index.html) is not here.
Possible Reasons:
You may have spelled the URL incorrectly.
This site may have been removed due to a violation of the CZ28 Free Web Hosting "Acceptable Use Policy".
This site may have been moved to a different server.
Old Dec 25, 2003 | 08:19 AM
oil pan 4's Avatar
I saw that, it worked earlier now this .
Injuneer
Apr 25, 2022 06:22 PM
lt1xondeck
Mar 18, 2016 07:22 PM
zFrank
Aug 12, 2015 03:46 AM
cmsmith
Jul 10, 2015 07:19 PM
