Oil Change light
Old Dec 29, 2003 | 05:41 PM
meangreen95z28's Avatar
Oil Change light
My oil change light came on after about 2000 mile since last oil change. So i changed the oil. But the light is still on. Whats up with this? Its a 99 firebird
Old Dec 29, 2003 | 07:10 PM
NoSlowCamaro's Avatar
I know im asking you a simple question..so dont think i'm tryin to be a smartass or anything...but did you reset??...i know the first time the light came on, i got it changed, and i was expecting it to just know that it had clean oil in it..but than i read the owners manual and found out you have to reset it manually, by holding the little trip/reset button down for 12 seconds
Old Dec 29, 2003 | 08:04 PM
99blackSS's Avatar
The holding down the trip odometer for 12 seconds way only worked for me until I turned the car on again. Turning the key to the accesory mode and then pressing the gas 3 times made it reset the way it is supposed to. So if the 12 second reset doesn't work try the gas pedal one.
Old Dec 29, 2003 | 11:36 PM
The trip reset worked. I bought the car used so i dont have an owners manual. Thanks for the help.
Old Jan 2, 2004 | 08:43 AM
r&ksport's Avatar
Post
2001 Camaro, 2002 Camaro
2001 Firebird, 2002 Firebird
1. Turn the ignition to RUN but with the engine
off.
2. Push the Trip/Oil Reset button located on the
instrument panel for 12 seconds. The Oil
Change light will start to flash to confirm that
the system is reset. The reset is completed
when the Oil Change light goes out.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
jj71787
Jan 31, 2015 10:20 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
