Is this normal
Old Aug 30, 2003 | 08:11 PM
3.8LCamaro98's Avatar
Question Is this normal
Well im new to camaros and dont know much about them so i have a question. Well when i park the car in a parking lot or drive way etc... and not turn off the engine but put the car in park or starting the car up the rpm needle kinda revs by itself it doenst go really high or anything but it goes between 1-1.5k rpm(it decreses gradually exp: 1.5k to 1.4 to 1.3 you get the point until it goes down to 1k and it stops) and i wasnt sure was this normal and if its not what is the problem that is causing this. Also it doesnt do it the whole time it just does it a few times and then it will stop. Please help me out and any help is greatly apperciated.
Old Aug 30, 2003 | 08:40 PM
99blackSS's Avatar
My 98 used to do that sometimes on start ups, it might still. Unfortanetly I forgot what caused it. Whatever it was, it was nothing major.
Old Aug 30, 2003 | 09:04 PM
Thanks 99blackss
bump =)
Old Aug 31, 2003 | 08:54 PM
Well todays it just went a little pass 2k rpm . Is this still normal or is there a problem.
Old Sep 3, 2003 | 10:56 PM
Update on the problem
Well i found out what was causing the idle problem. It happens whenever i have the a/c on. So i just want to know what is causing this idle problem and can i fix it myself and what would i need if i fixed it myself or would i just be better off taking it to the dealer since im new to the camaro.
Old Sep 4, 2003 | 05:47 PM
Ichoptop's Avatar
a good guess would be that turning on the AC draws power from the electrical system so the computer kicks the idle up to keep the system full charged. I would think that after driving a bit the engines idle wouldnt jump so much. You would be suprised at how many amps are needed to keep the AC, Cooling fans and electrical engine management crap pulls on a car. I personally wouldn't worry about it unless it happens consistantly with the AC on instead of being more of a "Catch Up" problem.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
