Need help finding Correct Pushrods
Old Aug 8, 2002 | 11:46 AM
pgriffith's Avatar
Post Need help finding Correct Pushrods
I have a 3.8 V6 Camaro. Its a '98. I recently installed some heads which are milled 20 thousandths. Will the stock pushrod work Or will I have to use something else?
I dont even know the size of the stock pushrod. But what pushrod will still give me the correct geometry?
Old Aug 8, 2002 | 12:09 PM
kmook's Avatar
Advanced Tech Moderator
Post
Griffith, Cant say for 100% sure as i dont read up or have that much experience with the V6s, but usually (for LT1s) a stock length pushrod would be fine for anything milled under 30 thousandths. There again the only way to know for sure, and the proper way to check, is with a pushrod length checker.
But nonethe less this is a regular tech question and should be posted in V6 Tech.
Thanks. Moving now-
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
HectorM52
Jul 30, 2017 11:46 AM
captcorvette
Mar 7, 2015 12:37 PM
sloppytot
Feb 25, 2015 08:30 PM
Jul 4, 2005 05:00 PM
