Muffler rattles really bad
Old Feb 18, 2004 | 09:56 PM
The Captain's Avatar
Ok, I have a Dynomax Super Turbo Muffler, and when its cold, its rattles REALLY bad. It also seems to rattle at exactly 1800RPMS, and whenever I rev it up, when the RPMs drop it rattles, and no time before or after. Just when its cold and at that RPMs, or after revving. Is something loose, or am I going to have to replace the muffler. Its not really all that bad, but just annoying I guess. I am hoping its something I can just fix. Thanks!
Old Feb 19, 2004 | 11:48 AM
ImportKILLER's Avatar
Bearings. Def the muffler bearings dude.
In all seriousness, without hearing it first hand, I'd be guessing. Crawl under and see if you can spot anything that might be loose. Maybe take it to a muffler shop and have them look it over.
Old Feb 19, 2004 | 04:01 PM
camaroguyo's Avatar
i had the same problem and all that was wrong was some heat guards were loose
Old Feb 20, 2004 | 01:59 AM
SFireGT98's Avatar
I have a similar problem. I've only had my flowmaster exhaust installed for about 3 weeks and now its starting to rattle a bit. Well thats what I thought it was but now I believe it may be a heat guard coming loose. Do you just tighten the heat guards back up or do you have to have them welded back? I'm gonna crawl under the car tomorrow and take a look.
Old Feb 20, 2004 | 09:49 AM
cabell84's Avatar
just tighten them back up, in fact, mine just started to rattle, so this weekend im going to tighten them up when the car is on the ramps when i change the oil. check the one on the intermediate pipe too. that one gives me the most problems.
Old Feb 20, 2004 | 01:06 PM
camaroguyo's Avatar
i had mine welded to make sure its not goin to happen every month, seems to be a common problem with flowmaster
kxrawx
May 25, 2015 08:29 PM
BLK1997Z28
May 7, 2015 03:01 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
brandboZ28
Jan 31, 2003 06:19 PM
